Results 1 to 10 of 15
Thread: Engine and Spanner Light Before I Start The Engine
    Regular Member corderz's Avatar
    Bradford
    Default Engine and Spanner Light Before I Start The Engine
    Hey guys,
    I had both the engine light and the spanner light when i turn the ignition, but then go once i start the engine. Now only the spanner light comes up.
    Any ideas what i can check? nothing coming up on my fault code reader....
    Does the spanner light go off as soon as the engine starts?
    Bradford
    Yes, but that spanner light doesnt come on anymore, its just the engine light now, then goes off
    West
    As long as there are no warning lights on when the car has fired, there should be no problem.
    Talking
    Thats the way its meant to be, just the engine light on its own when you switch on the ignition then going off straight away when the engine starts. If the spanner light comes on and stays on then you have a fault, if the spanner light comes on with the ignition and it goes off as soon as the engine starts it is indicating that a fault has been present but it has cleared. If this was the case the spanner light will eventually stop coming on with the ignition after 25-35 engine starts if no other faults show up.
    Just to contradict the above if the spanner light comes up along with an oil can that is lit as well it is telling you that the car is due a service.
    The above makes sense I hope.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by Rapala View Post
    Except that on facelifts the 'car and oilcan' icon is not used to indicate service due.
    The appearance of warning lights which disappear shortly after switching on the ignition and before starting the engine is part of a normal start-up diagnostics procedure. Perfectly normal.
    11 Post(s)
    Quote Originally Posted by john_k_sri View Post
    Correct. The word InSP appears briefly in the odometer display instead when you first turn the key.
    yorkshire
    Ho guys, I posted on another thread re this this week, my 05 1.9cdti has started doing this with the oilcan/spanner when starting and on shutdown, it was serviced by an independent about 2k ago, I have tried the reset listed on other threads but to no avail... Any thoughts anyone please it's really bugging me now
    Did you do it this way?
    Ignition off and press mileage reset button and hold it in, press the brake pedal down and hold it down. Now switch ignition to position two while still pressing the mileage button and the brake pedal until the service indicator resets.
    yorkshire
    I tried it with the ignition in pos 2, I will try it again as you describe and post back.. Many thanks... Fingers crossed. It says 1.000 under the spanner if that means anything
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. 2.0 DTI engine spanner light?
    By Thom in forum Engine & Drivetrain
    Last Post: 5th August 2011, 22:51
  3. Engine light, not spanner
    By Mr Hyde in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2011, 13:49
  4. Engine Spanner Light And No Power
    By yamkwak in forum Engine & Drivetrain
    Last Post: 9th April 2008, 22:40
  5. car & spanner + emissions (engine) light
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 20th August 2006, 21:11
spanner starts
spanner light before starting
Turn engine with spanner before start
