Results 1 to 10 of 14
Thread: Bass Rattle
    Regular Member Damian's Avatar
    Market Drayton
    Default Bass Rattle
    Since installing my new Sub in the boot I have noticed a rattle when the Bass is quite strong. Finally today I have tracked down it's source.
    The rattle only happens when the boot lid is closed. From what I can hear the rattle is the locking mechanism of the boot. When the boot is opened the rattle disappears.
    Is there anyway I can solve this (other than turnig the bass down a bit) or is it something I have to put up with.
    Jul 2006
    Mexico
    Welcome to the Bassss world mate....its very difficult to cancel all the shaking in the many probable sources......the problem is that it will get worst every time.....all the shaking will loosen things up gradualy.....at least that´s what happend in my last car.
    What I used to do was adding little pieces of rubber between shaking stuff...now for you specific problem in the locking mecanism of the boot it would be difficult to solve it...may be by making the "u" shape rod thiker some how to make the mecanism tighter.
    Mileage : 000
    Have you tried to adjust the latch in the boot, rather than the tailgate, it might stop the rattle.
    Market Drayton
    I am starting to find that, have had to move things out of the little cubby holes in the boot because they rattle !!!!!
    How do you adjust the latch ??
    It certainly sounds like the problem when I have my ear to it
    Here, there and every where!
    Is it the parcel shelf rattling against the hatch? There is a small piece of plastic in the middle of the shelf which you might need to remove. Stopped it on mine.
    Jan 2006
    Skynet HQ EMEC#5
    I think it's my fillings rattling in my car now I've fitted the bass tube
    Market Drayton
    Quote Originally Posted by Caterman
    Good call, will try this one tomorrow
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    You can always user Dynomat - sound deadening lining.
    Market Drayton
    Okay it wasn't any plastic clips rattling against the hatch.
    Still sounds like the boot latch, so how do I go about adjusting it
    torx insert screws around the boot catch on the rear panel, not the bootlid.
    slaken them off a little and gently tap the latch lower down. Retighten the bolts.
    It should hold it further down into the seal..
    As others have said, check all the rubber buffers are in place around the boot and the parcel shelf
  1. Bass Guitar..?? Anyone
    By macdad in forum The 'Off Topic' room
    Last Post: 25th December 2012, 09:58
  2. anyone got custom bass box ?
    By smirnoff sri-dti in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 10:21
  3. My bass bin...
    By smiley-sri in forum ICE Gallery
    Last Post: 23rd October 2010, 22:58
  4. think your ice (bass) is good
    By big rich in forum The 'Off Topic' room
    Last Post: 16th March 2009, 12:02
  5. Added a little bit of bass !!!!!
    By Caterman in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 18:39
