Thread: Outside temperature reading high?
    Mar 2007
    wight
    Default Outside temperature reading high?
    Hi, My outside temperature reading is all of a sudden reading approx 7 degrees too high? I did have a collision with a fox on the front offside at the weekend at high speed, would this have affected it?
    thanks
    Mar 2011
    essex
    It may have as on the front bumper there is a thermostat device/heat sensor, which reads outside temps, what ull prob find is that the sensor for it is touching the rad or a water hose causing to read high temps
    Mar 2007
    wight
    Hi, before even starting the car this morning the temp said 16 degrees, where abouts is the temp sensor, do you know? thanks
    Mar 2011
    essex
    Im not sure myself but ill have a look under my motor tomorrow, must be something silly anyway
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Behind the lower grille, passenger side.
    Mar 2007
    wight
    Thanks very much.
    Mar 2007
    wight
    Is it easy to replace, and will that prob be the fault?
    I thought summer was on its way this morning when it read 16.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    It could be. I got mine replaced on my old petrol 2.0T as it was showing 30 degrees in winter.
    Easy to replace, just unclip the old one and replace with the new one. Difficult part is having to remove bumper to get behind the lower grille, if you have to.
    On my old 2.0T there was a gap between the rads and the bumper large enough to just reach down into to get to the sensor, but on my current facelift diesel, there is no gap.
    Mar 2007
    wight
    Ah bumper removal, hoped it wouldnt be, never mind give me something to do I suppose. Never done it but will assume I will find some good instructions on the site.
    Oct 2007
    Shropshire
    Just check before you remove the bumper. I did mine by lying on my back with the front hanging over a kerb..... But as said they do vary!!
  1. Engine Temperature Reading
    By GerryB74 in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 21:23
  2. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  3. Temperature Gauge reading - AGAIN!
    By DurhamRed in forum Engine & Drivetrain
    Last Post: 26th September 2010, 18:01
  4. What's the lowest temperature reading
    By garvey in forum General Chat
    Last Post: 3rd March 2009, 11:27
  5. Temperature Reading gone with Bumper Fix!
    By globalpeace in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2008, 21:20
Outside temperature reading vaxhall vectra
vectra outside temperature
zafira outside temperature too high
