Thread: Plugs are so tight !!!
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    Default Plugs are so tight !!!
    Went to check the plugs today and OMG how tight some knob must of cranked them right down, Only tryed 2 and gave up scared to put real pressure on them in case the snap, Now would you do it with the engine hot or cold and has anybody got any tips ?
    Engine : 1.9 CDTi
    On what engine?
    Feb 2011
    wigan
    2ltr turbo fella
    West
    engine warmed up, pre soak with wd40 the night before
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    get it nice and warm to the point the fan cuts in etc, and as dh.dti said soak with wd but once youve cracked them loose let it cool for a while cos you dont wanna be burning yourself on the red hot engine or plugs, trust me it hurts, and make sure the engine its cold before refitting the plugs otherwise you will be in the same boat next time
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    My god, I read the thread title and thought it was going all porno
    Mar 2011
    essex
    Id also be very careful not to strip the thread, when you manage to get the plug out make sure its not stripped or cross threaded, cross threaded plugs would cause it to be tight, also before removing the plugs have a look down the spark plug holes, last thing you want is grotty water n rott getting down into the cylinders
    Aug 2010
    Leeds
    Get a strong bar on them or as we used to do the air gun.!!
    They have to come out & they probably have been in from new, so your lucky with a alloy head the cast iron heads were a pig.
    Remember they make a plug tap if you need it but you probably won't and some copper slip on the threads will be fine.
  1. How tight are you?
    By signum_rob in forum General Chat
    Last Post: 14th May 2012, 21:48
  2. Tight Van Man
    By Big Dave in forum General Chat
    Last Post: 16th June 2011, 11:07
  3. Why is Vx so tight?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 03:37
  4. Replies: 15
    Last Post: 2nd August 2009, 00:11
  5. hee hee im a tight wad!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2006, 21:57
