Thread: Glow Plugs
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Glow Plugs
    Reasonably certain at least one of mine is ka-puut but is there any harm in not changing it (them?) ASAP?
    Will it cause extra clogging or are they just to aid the cold starts?
    West
    only to aid cold starts... try turning the key a couple of times to bring the plugs on for longer in the morning, if you don't have the time to change them at the mo...
    Tain - Easter Ross
    I usually turn ignition on, then get comfy, stereo on, seatbelt on, pick my nose then scratch my bum then start car - do the plugs stay warming when ignition is on? Or is it as you say, on and off a few times?
    West
    on & off matey... if you do it 2 or 3 times it stops the spenner just after starting, providing it's only a plug or 2 out.
    it will become less of a problem as the weather warms up, i have just replaced all my plugs purely because i was doing the timing belt/water pump etc as part of a full service
    Mar 2011
    northumberland
    Hi, I have just joined the forum and could use a little help. Have just been told I need to get new glow plugs,could you tell me where is cheapest place to get them and is it a big job fitting them? I'm quite handy with a spanner so don't mind having a go. Have just spent a small fortune on the car (EGR,swirl valves,intake manifold,springs,battery) so need to save some money!! Any help would be much appreciated. Cheers.
    Engine : 1.9 CDTi
    Have a look in the guides section.
    West
    As above matey, look in the how to section & the plugs are £10 each at a dealer or motor factor
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Is this a glow plugs gone
    By Pjuk in forum Troubleshooting
    Last Post: 2nd March 2012, 16:20
  3. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
