Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Belt replacement advice needed 1.9cdti 150
  1. #21
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    the drain plug should have holes in it at the end, the idea being once you have unscrewed it a little the holes let the oil out in a controlled manner then when the flow has slowed down you take it all the way out, much better than just unscrewing it and moving quickly which usually ends up in me covered in nice hot oil lol
  2. #22
    Regular Member Mads's Avatar
    Ipswich,.UK
    have brought the 6 sided socket today and a set or mole grips as back up, hope the nut is not too rounded for the six sided to work! brought a 13mm but ive heard a 1/2 inch is a better fit?
  3. #23
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Mileage : 166000
    a 1/2 is a little smaller so if you can get it on then that might be a better bet
  1. Timing Belt Replacement
    By Dave_G in forum North East RO Vacant - ARO - Vacant
    Last Post: 25th November 2012, 12:34
  2. Stereo problem 1.9cdti advice needed plz
    By Dan. in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 23:07
  3. cam belt/chain replacement?
    By bigdan03vfr in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 09:50
  4. 1.9CDTi 150 Swirl Valve Advice Needed...
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 31st January 2009, 23:45
  5. Toothed Belt Replacement
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2006, 18:11
