Results 1 to 10 of 23
Thread: Belt replacement advice needed 1.9cdti 150
    Liverpool
    Default Belt replacement advice needed 1.9cdti 150
    I am just pricing up so I can get the dosh saved up, but I will be replacing the cam belt when car hits 60k (full kit not just the belt)
    But I am thinking while car is in bit I might Aswel change the other belts (to cut labour costs)
    So Aswel as changing cam belt I though to change..
    Water pump
    Fan belt
    Drive belt
    But am I missing anything that I should be changing? Car is staying until death do us part lol so I want everything running smooth for a long time!
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Full cambelt kit mate,belt,rollers and tensioner and water pump are the main things
    Liverpool
    Nice one!!
    £300 bill then
    Plus first Mot in sept!
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    and the aux belt that does the alternator and air con is just one belt that has to come off anyway as im sure your probably aware so the garage shouldn't charge you anything over the cost of the part to fit it, if they do just tell them you know it has to come off and will not take any more time to put a new one back on and if vx are doing it that they will be making money out of the part
    it may be £300 but is the water pump seizes and the belt comes of its atlest £800 for a second hand engine plus fitting or you have to have the rockers replaced hoping that the valves survived
    Liverpool
    Quote Originally Posted by vxpenfold View Post
    Very true!!!
    At least with everything changed I can have another 60k of trouble free motoring
    I might Aswel have every belt changed, Mot and service done
    Nice dint in the wallet lol
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    buts its worth it not to be wondering everytime there is a slight noise if its the water pump lol been there done that lol
    Regular Member Mads's Avatar
    Ipswich,.UK
    i Recently priced this up at vauxhall partsworld and then contaced vauxworld and they priced matched this for me and gave me an extra 5% off
    was £193.00 deliverd inc vat, well chuffed
    Sealant £5.85 + vat
    Sump plug O-ring 76p + vat
    Oil Filter £2.94
    Cabin filter £5.08
    Air Filter £6.98
    1ltr Anti Freeze £2.79 x 4
    Water Pump £29.50
    Timing Belt Kit £71.64
    Fuel Filter £7.54
    5w30 Engine Oil - 5ltr £13.50
    Drive Belt - £9.20
    Woodbridge
    Defo get the water pump done at the same time, as the cam belt has to come off to change that. As for the aux belt, I cant remember what has to come off to fit that.
    Woodbridge
    Quote Originally Posted by Mads View Post
    Sealant £5.85 + vat
    Oil Filter £2.94
    Cabin filter £5.08
    Air Filter £6.98
    Water Pump £29.50
    Fuel Filter £7.54
    Drive Belt - £9.20
    VX main dealer charge £550 for this less the drive belt!!!
    Ipswich,.UK
    Yeah Ginge7289 i got quoted that much less the drive belt at dealers, so i brought the above parts a jack and 2 3 tonne axles off ebay for £35.50 delivered and a haynes manual to accompany the how2 and that cost me £245.00 all in.
    cant get the sump plug off (rounded off) or the fuel filter out oif the canister so may have to take it in for just that, they have quoted me £72.00 to do oil and fuel filter change and thats including them using my parts and oil!!
  1. Timing Belt Replacement
    By Dave_G in forum North East RO Vacant - ARO - Vacant
    Last Post: 25th November 2012, 12:34
  2. Stereo problem 1.9cdti advice needed plz
    By Dan. in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 23:07
  3. cam belt/chain replacement?
    By bigdan03vfr in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 09:50
  4. 1.9CDTi 150 Swirl Valve Advice Needed...
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 31st January 2009, 23:45
  5. Toothed Belt Replacement
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2006, 18:11
