Results 1 to 10 of 26
Thread: Top Grille blanked off?
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Default Top Grille blanked off?
    I've noticed that during some recent "spirited" driving the engine temperature was significantly increased!
    Looking for a potential issue I noticed that the grille between the headlights is actually blanked off?
    Is this normal??
    What about the engine air intake that is behind the plate??
    Ive looked at other motors in passing and some are and some are not.
    Anyone have a view on this, should I remove it?
    Sodding Typical on Sea
    Any pics???
    I do know that behind the standard vectra cheese-grater grille is an aerofoil section that directs air not blocks it so am keen to see what you are seeing before I offer an opinion
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Err.... Your intake pipe should be situated mid way between the top and bottom of that grille, and NO it should never be blanked off.
    I'm not sure if i've understood your post correctly, could you supply a picture?
    Oct 2007
    Shropshire
    Don't worry mine is totally blanked off. Definately not a duct or anything. And yes the intake is behind it lol....
    I think its the small 1.8's that are blanked, as the radiator is the same as others but obviously it is smaller to cool.
    On the XER engine there is an intergrated oil-water cooler anyway and the undertray is not fitted due to oil temperature being the issue, not water temp....
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    I have a 150 CDTi?
    I will get a photo soon.
    The best way to describe it is a box! Fitted over the grille on the inside.
    The air con and water rads all extend up to the top slam panel behind this restriction.
    Regular Member madman's Avatar
    nottm
    maybe to stop water getting into the air intake
    Quote Originally Posted by madman View Post
    The air intake is situated so high, and with an airbox to stop water getting into the engine. I can't understand why there would be a blanking of it... Overheating an engine is basically as bad as filling the cylinders with water.
    Regular Member DARREN R's Avatar
    Jan 2008
    WASHINGTON
    Vehicle : vectra
    Trim : sri xp
    Engine : z19dth
    Mileage : 93000
    on my last sri i actually drilled a few holes in the section just above the chrome v grill in front of the air intake in the black plastic dont no if it had any real gains though cos did the airbox mod at the same time as i thoght the same that there was nowhere for the air to pass through the grill to the intake
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Mine is same top half of grill blanked off I have also drilleed holes in top plastic under lip of bonnet To get fresh air into the Intake pipe
    But I wonder if we could cut open the blanking plates to allow full airflow into engine bay and over radiators and intercooler
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The plate is there on Diesels to help stop Hydraulic Lock, its not fitted to petrol's. You dont get a "Ram" affect from the intake anyway so no point removing it really, although the choice is totally yours, however I have seen Diesels up close that have taken in water from large puddles/splashes that have been written off because they need new engines.
  1. blanked egr on my 16 valve
    By supersteve_75 in forum Engine & Drivetrain
    Last Post: 28th June 2011, 17:57
  2. EGR blanked, but...
    By cammy3000 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2011, 23:05
  3. EGR blanked 2.0 DTI
    By superfox233 in forum Engine & Drivetrain
    Last Post: 17th February 2011, 15:31
  4. can the EGR be blanked on the DTI??
    By mick 1986 in forum Diesel Engine related
    Last Post: 17th January 2010, 20:10
  5. Blanked reg plates
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2007, 03:51
