Thread: Wiring Plug For Bottle Sensor
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Wiring Plug For Bottle Sensor
    Tappetpaul Changed My Screen Today..Could`nt Find The Wiring Plug That Sposed To Be Taped Up Beside The Water Bottle..Do/Should All Vec`s Have It ?
    Paul Used The Earth Wire Method
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Mine does, its taped up on to the pump wire.
    Aug 2010
    Dundee-Motherwell
    Where Bouts/How Far ?
    Go Take A Pic lol
    Regular Member blackveccyC's Avatar
    Dumfries
    If you find the wiring going towards the lights branching off that 'might' be a wire like mine. I'm pretty sure it's connected to the bottle. But can't see. If you jack up the wheel, take wheel off and remove arch liner you'll be able to better, read some where some don't even have the wires ready to plug sensor in. Hope that makes sense.
    Did you get yours tech2ed or op-com yet?
    Dumfries
    Or on reading dasarabs comment it might be pump wire I can see. Will have closer look the morn and have a look for ya.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Not all Vectra's have the connector,
    but as described above, the sensor plug if it is fitted, will be taped up near to the washer bottle (close to the pump wire).
    If not, you could always wire your own in..
    Unscrew the Engine bay fuse box,
    Underneath this, you should see three big connectors..
    You want the second connector - pin 14.
    Run a wire from here, to your sensor plug (from a scrapper etc..) and then a second wire from the connector, to the chassis / earth.
    or if you don't want a sensor... but just want to kill the warning message, then simply put a wire from Plug 2, pin 14 - and run this direct to earth.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
  1. My washer bottle has no sensor!!
    Last Post: 27th October 2013, 20:21
  2. windscreen level sensor wiring plug - where?
    By NIGHTCD in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 16:51
  3. Wiring for the washer bottle sensor - where to find
    Last Post: 16th October 2010, 18:43
  4. washer bottle sensor
    By paulvectrac in forum Styling
    Last Post: 17th September 2010, 19:50
  5. washer bottle sensor
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 23:28
