is a zafira engine the same as a vectra?? as my vectra 1.9tdi turbo has gone, would i be able 2 put a zafira 1.9tdi turbo in it????????? thanks guys.
150bhp engine is identical to that in the Vectra. Not sure about the 120, could be the same (8v) or perhaps the 16v version.
hi mate, yeah its the 120 break 1, and yeah 8 valve, any help is good thanks
If 8v, it's identical to the Vectra one. Engine code Z19DT.
Astras are also the same. I have an astra 1.8 in mine.
If you have the 120 version check the one you are getting is the same (8v or 16v).
thanks, bought it now anyway, see how this goes. will let u know......also any1 know how much the egr valves are for the 1.9tdi 04 plate is? not having much lookwith this car!! thanks again
it dont fit,..why is this? aha my mechanic says it dont anyway!!!!!!!!!!!
the 16v 150 turbo will not fit on the 8v 120 either in a Zaffy or Vectra C
