Results 1 to 10 of 18
Thread: Washer fluid check.
    Regular Member blackveccyC's Avatar
    Dumfries
    Default Washer fluid check.
    Well folks finally got the GID screen fitted, and Im pretty sure I have the washer fluid sensor fitted. Wire tailing off the lights and connects to the bottle. Fluid alarm came up so topped up the fluid, but alarm still comes up even after stopping and starting car, not got stalk control activated yet but should this matter?
    Rgds G
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Does it come back on once the car has been switched off and on again? If it does and the fluid level is correct then you may not have the level sensor fitted.
    Dumfries
    Yeah fluid is up and like u say comes back on after every restart, I'll try take the wheel arch liner off to have a look, there's definatley a wire going into the bottle, could be broken or not connected properly? Will have a closer look the morn.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Could be any of three states
    1) No connector or wiring
    2) Sensor is fitted but either it or it's connector may be faulty / corroded or broken
    3) Sensor connector tied up out of the way, but there is no sensor.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If you've fitted the sensor, you may have put it in upside down, it's a float that is pushed up to close the contact while there's water there and as the water level drops so does the float, tripping the warning when it gets too low because it's broken the circuit.
    If you put it in upside down, it will actually float open, causing it to trip.
    If you haven't fitted it, then you probably don't have one, if the car had a TID fitted originally, it wont have the level sensor fitted, it may have the wiring though so you can fit one.
    There should be two connectors to the bottle, one for the pump and one for the level sensor.
    This is when I fitted my sensor on my old car (the sensor is the one on the right)...
    Dumfries
    right it becomes more clear now lol, Never got the chance today as it was mot fail day so there were more pressing issues. Once i get those out the way i'll have a look much appreciated for the pointers lads.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Ian You Got Any Linkys Mate On This.Re :Rubber Bung/Drilling Hole ..Got Screen Done And Lever In..Just To Get Sensor In Bottle And Tech 2 Done
    Cant Find My Wiring For Sensor..Mate Used The Earth Trick For Now
    Gonna Have Another Look Tomorrow But Think I Aint Got 1
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    You get the grommet from the dealer for a few pence mate, I just drilled a hole fractionally smaller with a hole cutter and sealed the grommet in with a small amount of silicon (trial fit the sensor before sealing the grommet though).
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by Ian-Highlander View Post
    Will Take The Sensor With Me And Tell Them Thats The Grommet I Need
    Cheers Ian
    Regular Member leonvectrac's Avatar
    south shields
    What sort of cutter did you use as i have this to do?
  1. low washer fluid warning.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 22:11
  2. Washer Fluid Indicator
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2012, 07:54
  3. Washer fluid leaking
    By monty2000 in forum Bodywork & Interior
    Last Post: 3rd February 2012, 11:47
  4. Windscreen washer fluid
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2011, 20:14
  5. Which washer fluid?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:15
vectra check washer fluid
