Thread: LED side bulbs
    London
    Default LED side bulbs
    Hi chaps,
    after having issues with the cheap LED side bulbs, I went for Canbus setas they apparently dont cause the warning message.
    After fitting both of them, the car displayed the message, though only for the left side
    So I thought it might be the LED bulb and swapped them over.
    Still both working perfectly fine, but again - left hand side error message.
    Any ideas how that is possible?
    Or is there any other option to get them white without using LED's?
    London
    Oh and I just read that I shouldnt use the once I am using anyway as the heat from the headlight will get it melted ..... whats ur experience with that?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Hard wire a second set off side light holders. See my profile.
    Regular Member Admishere's Avatar
    Oct 2010
    Irvine, Scotland
    Hi mate, I had the same issuse with the one side not lighting, dno what its caused by, but simple fix. Buy some load resistors, you can get from HIDs direct ebay store, this fixed my problem.. although, you will still get the strobe effect when the lights are off, I have my side lights on at all times to counter this. Any questions, HTH
    EDIT: I also had "canbus error free bulbs" thats the ones that only one side worked, had also bog standard leds too, done the same thing.. marketing!
  1. side light bulbs
    By rickeys16v in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2010, 21:19
  2. LED side light bulbs..
    By AngryDog in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2009, 16:25
  3. side light bulbs
    By linley85 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 20:40
  4. M-tec 501 side light bulbs....
    By bobby-tupper in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 11th January 2009, 20:30
  5. Side Repeaters - New Bulbs?
    By Leviathan in forum Styling
    Last Post: 12th February 2008, 18:33
