Results 1 to 2 of 2
Thread: Fault Code P0090......What Now?
    Regular Member ALAN B's Avatar
    Dec 2010
    East Lothian
    Default Fault Code P0090......What Now?
    Havn't been able to get car started after changing fuel filter, checked filter housing, connections, plugs etc - all OK.
    I have just had the car checked for error codes, garage cleared all the codes that turned up first time and one code kept coming back time after time.
    Code is P0090-5B Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation)
    Garage then checked if any fuel was getting to the fuel rail, loosed nut off the back of the rail and pipe was bone dry. Garage reckons the fuel rail / sensors / plugs are fine and throwing up the fault due to no fuel reaching it.
    Could it be the solenoid on the HP fuel pump? Fuel is definiently getting to the pump.
    Seems strange as car was running fine until I changed the fuel filter.
    Any ideas on what to do / try next? Dont want to start buying fuel pumps etc if there is a simpler solution.
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    did you ever get this sorted ?
  1. CDTI 150 P0002 & P0090 Codes
    By Nova_Turbo in forum Engine & Drivetrain
    Last Post: 12th March 2012, 18:21
  2. fault code P0090
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 1st February 2012, 22:10
  3. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
  4. p0090 fault rail pressure control
    By kamar in forum Engine & Drivetrain
    Last Post: 15th March 2010, 14:11
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
p0090 vauxhall
p0090 fault code
Opel P0090
p0090-5b vectra
vectra c p0090 www.vectra-c.com
https:www.vectra-c.comforumshowthread.php131889-Fault-Code-P0090-What-Now
vauxhall zafira cdti fault code p0090
p0090-5b
p0090 code vauxhall
p0090 fault
opel vectra p0090
p0090 vectra
Vauxhall DTC P0090-5B
p0090 5b
