Thread: 1.9 150bhp wont start after water pump and cam belt fail
    Mar 2011
    STOKE-ON-TRENT
    Default 1.9 150bhp wont start after water pump and cam belt fail
    This is actually on a 2006 Saab 93 with the same engine, had some advice before and all been helpful so thanks in advance.
    Had issue recently where car suddenly in limp mode, RAC suggested it was dual mass fly and followed me to garage.
    We noticed the swirl bar is off so may be part of issue but think its been like that for a while.
    Turned out to be the pump failed and belt was all loose, knocked timing out set off cam sensor and hence limp mode.
    Garagae has doen that and timed car using the 'special tool' which they had to get in special £100 (not to me but wonder if thats right).
    Now car wont start! Any suggestions? Can the swirl flaps issue cause a no start?
    Theres fuel up to the engine by the way.
    Rich
    Engine : 1.9 CDTi
    I take it they removed the cam cover to check for broken rockers incase there was piston to valve contact?
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    if not then chances are the low spped shudder as the engine shut down caused damage as said above
    Mar 2011
    STOKE-ON-TRENT
    they are looking at a fuel issue now, high pressure fuel pump although the car drove to the garage okay.
    Are these common issue? The car was difficult to start, had to turn over twice to get it to fire. But it go there okay, they say its got fuel to the pump but need to check it now to see if thats the issue.
    Anything similar to suggest?
    N.Ireland
    Over a year ago my water pump failed which then slipped the timing belt and there was damage done to the rockers and valves.The car wouldn't start and was towed to VX to get fixed and cost around £800 or so.
  1. Cam belt and water pump
    By tommythomson12 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2013, 15:06
  2. Replies: 4
    Last Post: 3rd September 2012, 01:26
  3. 1.9cdti wont start following waterpump/belt fail
    By richsimpson in forum Engine & Drivetrain
    Last Post: 9th March 2011, 19:57
  4. Cam belt+water pump?
    By Martinlw in forum Engine & Drivetrain
    Last Post: 13th October 2009, 18:55
  5. timing belt and water pump
    By mhvcbv in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 13:09
saab 1.9 dtzh no start
z19dth timing belt change and wont fire
vauxhall 1.9cdti wont start after pump replacement
saab 1.9 wont atart cambelt
changing cambelt z19dth
