Thread: 2.2 dti Starter Motor
    Sep 2010
    Grimsby
    Default 2.2 dti Starter Motor
    Have searched around forum but can't see any answers to this - How easy is it to change the starter motor on a 52 plate 2.2 diesel Vectra C? I have a Haynes manual which is telling me to go at it from underneath the car removing the entire exhaust assembly as well as a few other bits... is this all really necessary or is there an easier method?
    Cheers for any advice in advance!
    Sep 2010
    Grimsby
    A quick update to this question... called AA out yesterday morning, they checked battery, connections, etc - all ok. Said it was def starter motor. Got it going so took it round local garage who said they were too busy to look at it, so took it back home. It has now started fine every time! Is there any way I can get starter motor tested? Or one of my friends suggested it might be the actual connectors on the starter motor need cleaning? Anyone got any photos of the starter motor location as the haynes manual diagram isn't the best...
    Cheers!
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Starter motor is at rear of engine, if you look by right of turbo you will see the heat shield for it.I changed one on my Dti and it's a right pain due to limited space at rear of engine and you can't see what your doing half the time
    Irmscher Insignia CDTI 130
    Sep 2010
    Grimsby
    Cheers for the response bigmac! The car seems to be starting ok now... am gonna try and have a look at the connectors at the weekend n give them a clean as necessary.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Best do it from underneath then mate else you will be all over top of engine
  1. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  2. Starter motor help.
    By 123rado in forum Engine & Drivetrain
    Last Post: 6th January 2012, 21:30
  3. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
bosch starter motor vectra c 2.2 dti
vectra 2.2 dti starter motor
2.2 dti opel starter location
omega 2.2dti engine diagram starter motor
opel 2.2 dti starter motor change
vectra b 2.2 starter replacement
zafira 2.2dti starter change
how to wire starter up on vectra
vectra c 2.2 dti starter motor
how to wire up starter motor on a vauxhall signum 2.2 dti
vectra dti starter motor
vauxhall vectra 2.2 dti starter motor
vauxhall vectra starter motor location 2005
vectra 2.2 starter motor located
where is vauxhall dti starter motor
removal of vauxhall omega 2.2 diesel starter motor
changing starter motor vauxhall signum
Starter replacement 2.2 dti
where is the vectra c 2.2dti starter motor
wat does starter moter luke like in my 2.2 sri dti
removing starter motor signum 2.2dti
vectra c starter motor removal
