Hi guys, so looking at the front shock assembly, you have the plastic bearing carrier, then the metal upper bit which bolts to the car.
I can see the reason my you might replace the bearing carrier, as it can go noisey and wear away. But why would you want to change the metal upper bit? Or would you never really need to change that?
Reason i ask, alot of places do both components as a kit? id have thought youd just need bearing carrier?
Cheers
Mike
