Thread: Fan trouble
    Nov 2010
    Default Fan trouble
    My heater fan only works on number 4. I have a feeling there are resistors somewhere that have gone. How do I replace?
    Mike
    Nov 2009
    Lancashire
    exeter
    i got one from scappies with the motor and casing for £30 and its easy to fit . just remove the glove box and side panel and you should see it ? also check the pollen filter as mine was gutless on 1 2 and 3 . someone told me i could be leaves in the filter
    Feb 2011
    Selby
    See the other (long threads) on the subject - it's almost certainly just the thermal fuse. 82p and 20 minutes to fix it. But check your pollen filter too - the fuse blows when the resistors get too hot. They get too hot when there's not enough airflow to keep them cool. The airflow is restricted by a clogged filter...
  1. What next Fan trouble
    By nokiaman1978 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2011, 20:00
  2. Im having trouble with my
    By dannyjpuk in forum General Chat
    Last Post: 9th June 2010, 16:42
  3. Car trouble
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2009, 18:26
  4. Key trouble
    By rob123 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2008, 20:59
