Thread: Vectra SRI won't start / cuts out
    Mar 2011
    Accrington
    Default Vectra SRI won't start / cuts out
    Hi, I really hope someone on here can help as this fault is driving me up the wall! Right, it's a 2008 Vectra SRI 140 that I bought damaged and had professionally repaired (may not be important but I don't want to rule anything out). The damage was bodywork only and none of the engine components were replaced. I picked up the car from the repair centre and it was in limp mode (spanner light was on and car had no power). After getting the car home it refused to start again. The engine cranked over but would not catch. I bought a genuine Vauxhall service kit and replaced spark plugs, oil, air, fuel and oil filters. No joy. Used a diagnostic computer but there are no fault codes present or in history. Tried towing the car and starting and that worked but 30 seconds later the spanner light comes on and it cuts out. I know there is nothing wrong with fuelling, sparking, timing, compression as the car does drive when it eventually starts and I have tested the components separately. If it's a sensor would there not be an engine light and fault code present? I have searched this and other forums but the only similar problems have all been diesel engines and the problem has been vacuum pipes or something else diesel related. Hopefully someone can point me in the right direction. Thanks.
    lincolnshire
    has it got a fuel reset button ??
    Mar 2011
    Accrington
    Quote Originally Posted by bembo449 View Post
    I've looked in the boot and can't see a cutoff reset. I thought this was a Ford thing - am I looking in the right place?
    Mar 2011
    Accrington
    Update for anyone interested: the car is showing low compression in all cylinders. I'm having the timing checked to see if its jumped a tooth otherwise it looks like bottom end.
    Mar 2011
    Accrington
    It was the timing - out by two teeth. All fixed now.
    Engine : 1.9 CDTi
    Glad you got it sorted and thanks for taking the time to reply
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Happy motoring
  1. 2.0 DTI Wont start! ( and went it does it cuts straight out)
    By Daz_m in forum Engine & Drivetrain
    Last Post: 29th December 2012, 15:11
  2. 3.2 V6 wont start or cuts out when hot
    By Bomber G in forum Engine & Drivetrain
    Last Post: 20th June 2012, 16:55
  3. Cuts out
    By JaceyBoy in forum Engine & Drivetrain
    Last Post: 17th April 2012, 21:24
  4. cuts out
    By daddyjay in forum Engine & Drivetrain
    Last Post: 1st March 2012, 21:42
  5. Signum just cuts out!!
    By chriswoollett in forum Engine & Drivetrain
    Last Post: 21st March 2008, 16:29
