Results 1 to 10 of 11
Thread: caliper paint removal...
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Cool caliper paint removal...
    i've ordered a brake upgrade for my car from mann3210 but the calipers are painted blue, what's the easiest way to remove the paint off them as i will be painting them orange
    thanks in advance
    stephen
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Depends what they are painted with. If it's hammerite it will probably scrape off. Failing that paint stripper
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    ahh excellent will paint stripper be ok for it? (won't damage any of the insides?)
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Avoid getting it on the rubber and you should be fine. If they are well covered with paint then you could key the calipers with sand paper (or a wire brush) and paint over the top of it
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    they look like they have been done pretty damned well so might try that, they are in his for sale thread and look mint condition
    Regular Member Ginge7289's Avatar
    Jan 2011
    Woodbridge
    £50 is a bargain in my eyes, will look mint when they are on the car.
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Thanks ginge hopefully will look good
    Oct 2007
    Shropshire
    I would not try to remove it all. I would rub it down with sand paper and repaint.... I would not risk paint strippers anywhere near the seals!!!
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    also when fitting these brakes (302mm) i've read that the cars have heat shields behind the brake, so would these fit ok? or will i need new heat shields? my car is a 1.9 120 and has the 285 mm as standard.
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I think it might just be on the rear that you have to trim/change the shields mate. I went from 285-302-314 and never had to do anything to the shields
  1. caliper paint help
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 12:08
  2. caliper paint
    By DAVIDD88 in forum East Scotland
    Last Post: 8th March 2011, 19:43
  3. normal spray paint or caliper paint?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 20:59
  4. Caliper Paint
    By blr123 in forum Styling
    Last Post: 20th July 2006, 21:48
