Thread: cambelt tensioner postion correct???
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default cambelt tensioner postion correct???
    Hi
    I replaced my cambelt/water pump/v belt on the weekend and was well chuffed as this was the first time id done anything big like this on a car before but since then it has been bugging me that i didnt check the cambelt tensioner postion, so tonight i took it apart to check as it was eating away at me and luckly i think its spot on???
    so iwas just after your thoughts if this looks good to you, just to let you know that i replaced the tensioner for a new one, the back plate of the tensioner at the back (left side) sits forwards (right) to the old one as you can see where the old one was but as you can see the arrow is on the hole so i assume this is right????
    many thanks
    hope that makes sense
    Attachment 39224
    Ipswich,.UK
    anyone?
    Ipswich,.UK
    someone in the know please say this is right and put my mind at ease pleeeeeeeeeease
    May 2008
    Tyneside
    Haven't done a diesel, but according to Haynes manual photo that looks spot on for a Z19DT. HTH
    Ipswich,.UK
    thanks tridley
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yep thats fine ..
    Ipswich,.UK
    Thanks benny, just reading on here about the egr and boost pressure senor clean, i doubt its been done on mine but the car is running fine but i have the car and spanner light on more often than not but have read that could be conected to water in fuel filter too?
  1. Cambelt and tensioner kit changed but not waterpump
    By Meerkatonacid in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:33
  2. 2.0 dti throttle postion sensor problem
    By frankiebdv in forum Engine & Drivetrain
    Last Post: 25th March 2012, 14:15
  3. HELP Play in new cambelt tensioner 1.9 cdti
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 25th March 2012, 13:21
  4. Setting cambelt tensioner 1.9cdti 150
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 28th August 2010, 13:31
