Thread: How do I reset needles after stripping speedo?
    Jul 2009
    The Rift, Cardiff
    Default How do I reset needles after stripping speedo?
    As title, the revs sit just above zero while idling now. Is there a method for resetting them to zero?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Trial and error mate. That's all i did. It was the fuel gauge that worried me. I filled it up and did the fuel. Ran it to temp and put that needle on, idled at 750, took for a spin on the motorway using satnav.
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Had this after doing led conversion. When you take the needles off, twist them anti-clockwise while pulling up at the same time. When you put needle back on, line it up and ONLY press down, slight anti-clockwise is ok but not clockwise. Also make sure the bottom of the needle isn't making contact or catching the speedo fascia.
    Hope this helps bud? Good luck
    Jul 2009
    The Rift, Cardiff
    Cheers for the replys, all sorted now
    I did the speed, temp and fuel anti clockwise but got fussy with the revs needle and moved it clockwise too. I'll have to double check the speed with sat nav, it was generaly -3mph before.
    Happy with the blue, vast improvement.
    Regular Member trickyjacks.4's Avatar
    nottingham
    Default dash conversion
    alright guys I hope someone can help,I did my led conversion last year and was chuffed to bits with it. I realised recently my speedo was out by about 5mph so I took it out yesterday and adjusted it but in doing so I turned it clockwise(yes I know) and hey presto the speedo doesn't work anymore,is it fudged or can it be repaired.Any info would be appreciated.
  1. speedo needles
    By jimbo1987 in forum Styling
    Last Post: 5th March 2012, 21:58
  2. Clear speedo needles
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 20:40
  3. gsi matt chrome speedo needles
    By mhvcbv in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 3rd February 2009, 20:42
