Likes Likes:  1
Results 1 to 10 of 18
Thread: Will not start after changing fuel filter???
    Regular Member ALAN B's Avatar
    Dec 2010
    East Lothian
    Default Will not start after changing fuel filter???
    Changed the fuel filter on my 05 1.9cdti sri and it will not start now.
    Never had this problem when changing filter in the past.
    Fuel filter housing is filling up, fuel pump is running and engine is just cranking over, not a sign of it even attempting to start.
    Checked all plugs, hoses, pipes etc, nothing loose or leaking.
    Car was running fine before this, so cannot understand how changing the fuel filter could cause any major problems.
    Any help or ideas would be appreciated
    Mar 2011
    S
    Working in car parts and i have seen the odd damaged filter coming back. Maybe worth trying another one/old one to rule this out.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Is it the right way round????
    Fuel flowing in direction of the arrow etc..??????
    Dec 2010
    East Lothian
    Genuine filter from local dealer and it was fitted the correct way into the housing, with the arrow alligned and a small twist to lock it in.
    From what I can tell/feel the large flexible pipe that joins to the feed pipe from the from filter housing was soft to squeeze, after turning on the ignition on and the fuel pump run for about 10 secs, the flexible pipe was solid. This makes me think the fuel is passing through the filter.
    Dec 2010
    East Lothian
    Just had a mate have a look at it and the filter is pressurising and fuel is passing through the filter etc at pressure.
    Filter is fitted correctly and housing ring seal is tight enough at 30Nm.
    Tried bleeding any air in the system at the injectors, but fuel is not reaching the injectors.
    Also got a yellow engine shaped light at the bottom right hand corner of the dash when trying to start engine, cannot remember if it was there before or not.
    Any ideas if it is a sensor, knackered injection pump or a fuel blockage?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    are all the plugs on correct on the filter houseing ?....both of them ..??
    Engine : 1.9 CDTi
    Check all the rubber seals
    Dec 2010
    East Lothian
    Checked the plugs on the filter housing, both ok.
    Plug on the bottom of filter housing git a bit of a soaking in diesel, when I first removed the filter housing, but dried it off best I could before refitting.
    What rubber seals are you refering too???
    Engine : 1.9 CDTi
    From what I remember there is a small one that gets changed but sometimes gets dislodged.
    Dec 2010
    East Lothian
    The only rubber seal that I touched was the one on the filter housing which was replaced with a new one
  1. Changing fuel filter
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 16:28
  2. changing the fuel filter on a DTI
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 12:30
  3. Changing Fuel Filter
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 10:21
  4. Changing Fuel Filter
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 11:41
  5. changing the fuel filter?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 21st December 2008, 17:10
why does my vectra not have fuel filter
vectra after changing fuel filter doesnt start
i changed the filters on vectra 1.9cdti sri and now it wont start
how to change fuel filter 2005 opel vivaro
vauxhall vectra wont start after changing fuel filter
garage removed replaced fuel filter now wont start
https:www.vectra-c.comforumshowthread.php131814-Will-not-start-after-changing-fuel-filter
toyota will not start after changing fuel filter
19 cdti vectra changed diesel filter not startvivaro changed fuel filter now hard to startvivaro 1.9 dti fuel filtercar not starting after changing fuel filtervectra diesel not going to filtrI have a fuel drip from my vectra fuel filtervauxhall zafira diesel fuel filter changed now wont start problemsvectra c 1.9 fuel filter problemsdiesel wont start after fuel filter changevauxhall vectra 1.9 cdti wont startvectra change fuel filter not startcorsa c cdti wont start after fuel filter changestarting car after fuel filter change vectra c 1.9cdti sripetrol vectra starting problems afrer refuellingvauxhall astra 1.9 cdti get fuel no starthow to change a fuel filter on a vauxhall zafira dieselproblem after changing fuel filter vivaro 1.9
