Thread: interior light prob
    york
    Lightbulb interior light prob
    just had roof lining down to fit rear int light but now int lights not working all together which ids a major prob as i work nights taxi'ing any ideas as to why it would just stop working
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    Maybe a fuse????
    Jul 2009
    The Rift, Cardiff
    Lose connection possibly, the ribbon cable runs down the c pillar to the fuse box in the boot and may have been tugged from it's plug. Also check the flat ribbon-cable-connector-block-pad-thing, it's easily damaged.
    york
    now have safeguard up on dash
    Jul 2009
    The Rift, Cardiff
    As said check all connections. Check the plugs on top of the front light too, the ultrasonics are by the front light and also run off the ribbon cable to the boot.
    New Member german021's Avatar
    Jun 2009
    Manchester/ UK
    Need some help here please... My interior light is dead bulbs are fine, fuses checked, fitting checked. No voltage on ribon by the fitting with doors open or closed. Checked with Tech2 but nothing found. Any suggestions for me please...the interior light, the ribon is that the same one that is linked to REC in the boot? Does it go all the way to the back? Because there is voltage on the pins in the back...One day just got into the car put the the light on and after 10 sec light started to blink and off it went...
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  3. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  4. head light prob
    By wolfie1 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2008, 20:14
  5. side light prob HELP!!!
    By maniac8569 in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2008, 11:38
