Thread: Rear door mouldings?
    Derbyshire
    Default Rear door mouldings?
    Hi all.
    My Mrs very kindly reversed the Vectra along the side of the garage yesterday!
    Luckily, it all hit the rear door moulding!
    So just wondered how do these come off & are they easy to replace?
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Quote Originally Posted by Davies20 View Post
    Hi all.
    if its a drivers side one ive got a new one here in you can have cheap just need s painting
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I think they come off quite easily but you have to remove quite a bit from the door. PM me when your doing it, if I'm free I'll give you a hand.
    PS, I know a good bodyshop in Chesterfield if you need one.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    But does it/ do they (the side rubbing strips on all doors) unclip from the door or are they fixed to the door panels with pegs poking through the door panel & secured by nuts inside the door panel similar to the rear chrome strip fitted to the boot/hatch lid ????
    I need to remove mine to paint it.....see below posted another thread "Hit & Run!!! AGAIN!!!!
    http://www.vectra-c.com/forum/showpo...4&postcount=21
    Derbyshire
    Quote Originally Posted by lee_umney View Post
    Thats brilliant, thanks very much!
    Quote Originally Posted by Tony W View Post
    And also what this guy said. Are they glued on, or screwed / clipped?
    Derbyshire
    bump!
    Regular Member Jezzy's Avatar
    S.E
    There are clips at each end that look like they need to be compressed from inside the door using pliers (after removing the door card). There are also two locating pegs, one about a quarter of the length in from each end. Plus there is double-sided tape all the way around the edges of the moulding, with wider bits of tape being used on each end.
    Derbyshire
    Brilliant, thanks very much!
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Thanks for that jezzy...appreciated....
    So its' a case of stripping off the inner trim off the doors & card eh???
    Then trying to pull the strips off the sticky double sided tape after unclipping 'em ...& hope they don't bend/snap in the process ...
    In other words..for me....
    Think I'll have a go at rubbing the scratched ones down carefully while they are on the car & apply a couple if light coats of Lighting Silver Z163 Standard shade spray paint I bought for the parking sensors I fitted a couple of years ago.....carefully masking up the body panels around 'em.....& see how they look.
    Will show before & after shots when I do it....when the weather gets a bit warmer.
    Derbyshire
    Just take the ******s off you wimp! :P
    We'll have a joint rub strip removing day if you like lol
  1. rear door tweeters
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 13:20
  2. Door Mouldings
    By sol in forum Bodywork & Interior
    Last Post: 2nd September 2011, 13:35
  3. rear door card
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 20:36
  4. Irmscher Bumper Impact Mouldings for Pre-facelift
    By SRiXPT in forum Parts for sale
    Last Post: 26th March 2010, 17:43
