Thread: Checking Valve Clearances - 1.9CDTI (Z19DT - 120)
    Wales
    Default Checking Valve Clearances - 1.9CDTI (Z19DT - 120)
    According to the service schedule, the valve clearances on the 1.9 120bhp 8v engine (NOT the 150bhp 16v) need checking every 40k/4 years.
    From what I can gather the 150 16v uses hydraulic lifters, so is self-adjusting, but the 120 8v uses shims. Anyone ever adjusted them on a 8v?
    The actual procedure seems easy - point cams upwards and check clearances, but Vauxhall seem to specify two special tools when doing this job EN-46797 and EN-46799 which presumably help you to comress and then hold the valve down, so you can take the old shim out (if necc). anyone know what these tools are or look like?
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by snapsnap View Post
    Anyone know what these tools are or look like?
    Sorry for digging up an old thread but thought it may help others
    I'm going to be looking into doing my valve clearances when it gets a bit warmer but just had a search on Google to see if I could find any of the special tools required and found these:
    EN-46797
    EN-46799
    In case the links no longer work at a later stage, I took a quick pic of the pages and have attached them below to help others
    Attachment 48971
    Attachment 48972
    Hope it may be of some use to you guys
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Wales
    The first tool is used to depress the valve and the second to hold it down. When I was looking into this I too found those tools, but just ended up using a vary large flat blade screwdriver to depress the valve and then a stubby flat blade screwdriver to hold the valve down.
    Depressing the valve is easy; it just needs a good hard downward shove, keeping the thing held down while wedging something between the valve and cam is the tricky bit. You get pretty fatigued after about 5 - 10 secs!
    The only tool worth getting is the second one, but it is totally doa-ble with just two screwdrivers, a magnetic tool and pliers.
    First time round is also a pig as you need to remove the valve shims to see what size they are (to allow you to order correct replacements), reassemble, order the new shims, remove shims again at a later date and insert correct ones.
    Second time round is easier as you already know the valve shim sizes that are installed.
    Also, to get the cam lobes pointing upward to allow the clearances to be checked, just crank the engine on the starter
    Wales
    Duplicate post
    Oct 2010
    lincoln
    What is the clearance for exhaust and inlet? is it set hot or cold?
    Year : 55
    Mileage : 92,000
    According to the Haynes manual:-
    Valve clearances
    Engine cold (inlet and exhaust).................0.30 to 0.40 mm
    HTH
    Damo
    Already replaced:-
    Alternator,
  1. Z19DT valve clearances
    By C-Owner in forum Engine & Drivetrain
    Last Post: 15th August 2012, 11:57
  2. EGR Valve For 1.9CDTI 120 8v
    By bazal in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 18:05
  3. 1.9cdti 120 egr valve
    By fattony in forum Engine & Drivetrain
    Last Post: 23rd October 2010, 10:43
  4. New 1.9CDTI DMF Z19DT - £100
    By danBoy in forum Parts for sale
    Last Post: 7th January 2009, 19:39
  5. New EGR valve £305 fitted!!!! 1.9CDTi
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2008, 22:22
vectra 1.9 valve clearance
vauxhall vivaro valve clearance
EN46799
z19dt tappets
opel astra tdi valve clearance
asrta 1.9 cdti valve shiming
vivaro cam bucket shim sizes
vauxhall valve clearances
2006 vauxhall vivaro valve clearance
z19dt shim
z19dt en46797
vectra 1.9 cdti engine valve adjustment
Vectra cdti z19dt
zafira z19dt 1.9cdti valves
vauxhall tool for shim removal
opel-en-46797
vectra cdti valve clearances
Vauxhall valve shim tool
Vauxhall tool en-46797
opel 1.9 cdti clearance
vauxhall diesel valve shims
en 46797
narzedzie en-46797
vectra 1.9 cdti valve clearance
