Thread: Offside Steering system has slight free play detected at steering wheel (2.2.A.1b)
    Birmingham
    Default Offside Steering system has slight free play detected at steering wheel (2.2.A.1b)
    Folks,
    Just been to see another Astra and checked the MOT's on the car, this was an advisory at the last one, what exactly does this mean?
    Offside Steering system has slight free play detected at steering wheel (2.2.A.1b).
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Jezzy's Avatar
    S.E
    At a guess, it means that when you jiggle the steering wheel, the driver's side wheel doesn't move as quickly as it should, i.e. there's some slack in the suspension. Probably caused by a worn bush, maybe the track rod end.
    Birmingham
    Weird, I'd have thought they would have stated Track Rod....? Could be just tracking out?
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    There won't be an advisory type for all components, it will be a blanket description.
    As above, I would say the track-rod end.
    S.E
    As Dan said, they often tell you the symptom rather than put their money where their mouth is and tell you the cause.
    Sodding Typical on Sea
    Yip I reckon either the track control arm or rod end has play, the wife's last Golf had the same and it was the track control arm balljoint.
    East Ayrshire
    Trim : SRI XP1
    tracking being out wouldnt cause it either, everything would still be tight. if you lie under the car and get someone to turn the wheel all the way out then rock the steering back and forth, not much and look for play, it should be visible
  1. Offside track rod end ball joint has slight play
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 19:08
  2. mot advisory offside inner steering rack joint has slight play
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 12:29
  3. Slight grinding through Steering wheel.?
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2010, 13:15
  4. Steering Wheel Free-Play
    By freddy in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2009, 16:42
  5. free play on steering wheel
    By andys964 in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2009, 02:17
steering system has slight free play
Nearside steering system has slight free play detected at steering wheel
Steering system has slight free play detected at steering wheel (2.2.a.1b)
https:www.vectra-c.comforumshowthread.php131799-Offside-Steering-system-has-slight-free-play-detected-at-steering-wheel-(2-2-A-1b)
offside steering wheel play means
Steering system has slight free play detected at steering wheel (2.2.A.1b) corsa c
