Thread: EGR Mod failed
    Full Member Teapot's Avatar
    woodbridge, suffolk
    87 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default EGR Mod failed
    On the Z19DTH engine, I was getting the typical EGR fault symptoms of no power below 2000rpm. Strangely, this only occurrs on warm days once the engine is thoroughly warmed up, and there were no fault codes.
    Anyway, I dismantled and cleaned the EGR valve in accordance with the howto, and fitted a blanking plate with a 6mm hole as several others here have done.
    Whilst I was at it, I cleaned the throttle body and the channels in the the intake manifold. I also verified correct operation of the swirl valves.
    The fault still persists and this morning the spanner light came on. Diagnosis with the opcom shows 'EGR insufficient flow'. So the 6mm hole trick didn't work for me, so I'll be removing that mod :-(
    It has only been 2 years and 26k miles since the EGR valve and manifold had been replaced (at the stealers by the previous owner!). Surely the EGR valve can't be knackered already? The solenoid part was spotless and everything else seemed to move freely and seal properly when closed. Is there anything else that could cause this symptom?
    scotland
    Hi, did you strip down the egr solenoid and clean all they parts?
    Sorry just noticed you said that it was spotless...sorry.
    Regular Member Diesel Dude's Avatar
    Norfolk
    Just a thought have you checked the vacuum/boost pipes for leaks?
    Regular Member Innes's Avatar
    Plymouth
    It sounds like a vacuum pipe issue. They are easy to get to. Here is a thread about it.
    http://www.vectra-c.com/forum/showthread.php?t=109454
    You can buy silicone replacement pipes off ebay.
    http://cgi.ebay.co.uk/4mm-BLACK-SILI...item43a58d8a52
    Dec 2010
    Cumbria
    I thought the hole had to be 8.5mm to stop the spanner light coming on?!
    Not sure where i saw it though!
    Regular Member djr69uk's Avatar
    Midlands
    yeah think i've seen some posts where people had to enlarge the hole to stop the spanner light coming on. just try 0.5mm wider each time until the spanner light no longer comes on.
    woodbridge, suffolk
    87 Post(s)
    Trim : Design+
    Mileage : 101000
    Yes, good point. i'll replace the whole lot even if they look ok. thanks guys!
  1. Failed M.O.T
    By lanky659 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 10:39
  2. Failed MOT
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2011, 13:54
  3. MOT failed :-(
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 20:14
  4. Vec failed its MOT
    By JusSRi in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2009, 19:48
  5. Tried & tried but failed doing what?
    By Tadpole in forum Bodywork & Interior
    Last Post: 4th May 2009, 19:26
