Results 1 to 10 of 14
Thread: heater resister were from?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default heater resister were from?
    i want to fix my heater blower it works on 2,3,4 but not 1 whats that resister i need? relay must be ok because i can hear a click when its on 1 but when i look at the blower it dont move, also where about is the resister?
    cant find the how2
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by chris1804 View Post
    cant find the how2
    search resistor, heater, thermal fuse in the search box
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3cb4c8884e
    it will cost you about 32 pounds at the dealer
    Oct 2009
    Sandwell
    Quote Originally Posted by vectra ste View Post
    im sure theres a part you can get from maplins but i aint sure wich one it is
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    Oct 2009
    Sandwell
    sorted just rang maplins they have them in stock,
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    glad to have helped mate
    {making vectras easier to live with}
    Oct 2009
    Sandwell
    whats the best way to connect the resister i thought soldering it but just read up and because it gets hot solder wont hold
    Feb 2011
    Selby
    If the fan only works on position 4 (nothing on 1,2 or 3), then it's probably the thermal fuse that's gone. This is the 82p part from Maplin. Unless you're very good, you can't solder it (because it is designed to break at 240°C), so you need to use screw or crimp connectors to join it's wires to the remains of the old fuses wires.
    If it works on any of 1,2 or 3 then the fuse is intact. You cannot replace the resistors individually, so if it works on some but not others then it's either a faulty switch in the heater controls, or you need a new resistor pack - £25 from VX.
    Oct 2009
    Sandwell
    Quote Originally Posted by rich r View Post
    only works on 2,3,4 not 1 ill give it ago if it still dont work ill get a new one
  1. signum heater resister
    By neil52 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2012, 21:41
  2. signum heater resister
    Last Post: 28th October 2012, 19:58
  3. resister
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2009, 23:25
  4. Is the a way 2 test heater resister on a vetra
    By eddie lane in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 19:08
