Results 1 to 10 of 13
Thread: A.B.S.Sensors
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default A.B.S.Sensors
    My A.B.S. Light Is On,Need To Investigate It..
    Many A.B.S.Sensors On My Vec ?
    Anyone Got A Pic Of Sensor ? lol
    Aug 2010
    Dundee-Motherwell
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    The ABS sensors on the front are built into the front hub, you can't really do that much with them.
    Not sure about the rears.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    All of the ABS sensors are built into the hubs. You need to get the car plugged in to diagnostics to see what the problem is as it could be anything
    Also its not very likely to get a reply within 15 minutes at half 7 in the morning
    Aug 2010
    Dundee-Motherwell
    They Cleared The Threads..Was Bumping It To Bring It Back Up
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Tam80 View Post
    Thats only for your account mate, anyone else logging in would still see it in their 'new posts'
    Aug 2010
    Dundee-Motherwell
    Didny Know That..As I Never Go Look @ Posts In Forums Unless Am Looking For Summit..I Only Keep Looking @ New Posts lol
    You Got A Pic Of A Sensor John ?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I could post a pic mate but it would just be a pic of a hub with a wire coming out of the back
    The most you could really do would be to check all of the multi plugs for corrosion. If it is a knackered sensor then you'd have to replace the whole hub
    Aug 2010
    Dundee-Motherwell
    Will Go Oot Shortly And Check Them Mate..I Got U480 Code Reader..Well Think Thats What You Call It..That Aint Pickin Nuttin Up
    Sep 2010
    6 Post(s)
    Trim : SRI
    Check the wiring between the hubs and the plug, seen it a few times where people have said the wire had broken inside the sheath.
  1. IAT & MAF Sensors
    By Big_Rich in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 21:55
  2. Abs sensors
    By nikroc in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 11:07
  3. 2.2 dti sensors
    By tomo610 in forum Diesel Engine related
    Last Post: 17th December 2010, 12:27
