Thread: 2.2 direct revs stay high from 1st to 2nd
    Feb 2011
    nottingham
    Default 2.2 direct revs stay high from 1st to 2nd
    Hi i am new to this site, used a site for my wife with a different car and found it very useful.
    I have a Signum 2.2 direct petrol 2007 model manual gearbox. I bought the car just over 3 years ago with 6000 miles on the clock, it has now done 63000 with no problems. Except and it as done this since i got it,
    when accelerating in 1st and changing to 2nd the revs seem to hover for a few seconds but by this time i depressed the clutch to change gear and you sound like a right amateur. This model does not have a cable fitted and main dealer as checked this twice when the car has been serviced.
    I have drove vauxhalls for past 8 years but this is starting to get me down
    as it spoils the drive.
    Does anybody have any ideas they would be welcome.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Hi I have a 2.2 direct and have not long changed it from a 2.5 v6 which i had for 6 years with a cable throttle, the revs on my 2.2 always go up every time i change gear, its like I have comne off the throttle too late before depressing the clutch, I have even checked the throttle pedel spring to see if it was stretched and not allowing the pedel to return quick enough, I thought it was me not use to an electronic throttle but mine might have a fault as well.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    No chaps, that's how it is. You get used to it eventually.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    ah well if thats the way it is better start learning to come off the throttle sooner before depressing the clutch.
    Feb 2011
    nottingham
    Thanks for the replies i just thought it was mine, you do get used to it but if anyone has any more info it would be interesting. Do other petrol models do it or are diesels the same as well.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Even the 3.2 does it. Is it part of the drive by wire (Electronic throttle) lag? Or is it something else?
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    Quote Originally Posted by 2.2elite View Post
    When I test drove a couple of 150 diesels they did not seem to do it, they had other faults instead!!
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. Revs stay up
    By wee-willy-winky in forum Engine & Drivetrain
    Last Post: 15th April 2012, 17:18
  3. high revs when hot
    By mentor in forum Engine & Drivetrain
    Last Post: 26th May 2011, 12:36
  4. Revs stay higher longer than expected
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 12:32
  5. Car and spanner after high revs
    By Chuddy in forum Petrol Engine related
    Last Post: 5th February 2010, 22:43
