Thread: spanner light.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Default spanner light.
    any help would be great.
    when putting foot down in 3 rd n 4th it goes into limp mode.
    iv had fault codes read p1105-fa.
    when checking boost pipes are they ment to become pressurized when car is parked but revving, revved to 3 or 4 thousand and my pipes still are not pressurized.
    cleaned egr, boost sensor, Barometric Pressure sensor and few other bits not sure of there names.
    thanks
    Regular Member Tony12's Avatar
    Peterborough
    Engine : 1.9 CDTI
    Mileage : 142000
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Have you tried this yet? I have the exact same issue and the cheapest MAP sensor I can find was £44 at gsf...
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    i tryed cleaning everything. i can stop limp mode by cable tieing the actuator (waste gate) open.
    will this damage turbo?
    any guesses weather its the map sensor or the vacuum solenoid?
    cheers
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    West
    have you checked all the boost pipes & intercooler for leaks as well as looked into a falty sensor
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    yes all vacuum pipes are good. had a good look at intercooler pipes can not see any splits.are they ment to come pressurized when reeving in neutral
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    right does turbo only boost when waste gate starts to open? revving in neutral pipes stay soft open wastegate and they become pressurized and have no leaks. im guessing the vacuum aint working how do i test this?
    iv tryed finger on pipes when ticking over and its got a tiny bit of suck.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
