Thread: Access to windscreen wiper linkage
    Mar 2011
    Sheffield
    Default Access to windscreen wiper linkage
    How do I remove the black grill between the bonnet and the windscreen, to gain access to the windscreen wiper linkage?
    fife
    remove wiper arms, remove rubber seal that runs along lengh of panel then carfully prise away from under windscreen...
    Aug 2009
    sheffield
    its a pig. cracked mine on first attempt. budget windscreens of shefffield will remove it for a fee. 01142215630 / S4 8DT. or get your finger nails under trim at one side,and pull.its pressed into a channel.
    Mar 2011
    Sheffield
    Thanks for your replies, I'll give it a try. I'm hoping to sort out the wiper linkage mechanism after my passenger side wiper stopped working. From what I've read on here it sounds like this fault is a well known design feature!!!
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by kcmillar View Post
    I removed mine three times recently & posted in another thread, when I had problems with the wiper functions & finally changing the wiper motor...& yes it is difficult...but I didn't damage anything - deflector or windscreen by cracking it etc....
    I started @ the passenger side windscreen pillar..easing up the corner CAREFULLY & GENTLY then inserting a spare broad wooden spatula (Nothing metallic) that my wife used with a frying pan...& working CAREFULLY & GENTLY easing the deflector away from the windscreen & trying not to use the windscreen as the fulcrum point..across to the drivers side windscreen pillar.
    I also found I needed a windscreen wiper arm puller tool....as the arms would not budge off their splines....
    Clipping it back is much easier but again you need to be gentle & careful, making sure the ' lip strip' on the back of the deflector locates correctly in the narrow recess running along the bottom of the windscreen...pushing it firmly into the recess when it is positioned correctly....
    Hope it helps...
    Aug 2009
    sheffield
    like the wooden spatula method tony w. i used www.wipex.co.uk for the up graded push rods. pull out the red sq thing ,on motor to release the wiring block
    Feb 2011
    Selby
    It's interesting how my Vectra had a new wiper linkage fitted the day before I picked it up, and strangely had a cracked windscreen close to the passenger side wiper shaft that wasn't there before they removed the plastic cover.
    I suspect that they levered against the glass a bit too much...
    Still, new windscreen fitted now, at the garage's expense
    swansea
    From what I've read on here it sounds like this fault is a well known design feature!!![/QUOTE]
    Once you start looking for spares, you realise it's a design fault on many cars.
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Our 55 reg facelift Vectra C Z`18XE Club has the modified wiper mechanism identified with the white plastic pivot/bushes......
  1. Vectra windscreen wiper linkage
    By Andt78 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th August 2012, 16:59
  2. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  3. Windscreen Wiper Linkage on Signums same as Vectras?
    By o9roberts in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 22:46
  4. Windscreen wiper linkage failure
    By Leviathan in forum Bodywork & Interior
    Last Post: 16th November 2009, 19:02
vectra c wiper arm removal
vectra c wiper linkage
how to change the wiper motor on a signum
how to access wiper linkage
how to remove wiper motor in vectra c facelift
