Thread: Help - cannot get brake shoe piston back in, cant open bleed nipple
    HULL
    Default Help - cannot get brake shoe piston back in, cant open bleed nipple
    Help - is the bleed nipple suppose to unscrew (nipple witha nut shape at the bottom) , if so i cant get it off, and i cant screw in the winder , im in a right mess
    ..someone on here mentioned about the brake reservoir ? , where do i find that ,as it might be my only option to get the pressure relieved , so i can push the piston back in
    Regular Member mann3210's Avatar
    scotland, perth
    i had the same problem with my mates, had to get a mechanic to look at it, im sure he got someone to pull the handbrake on & off while he wind it back in! someone here will know
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    try boiling kettle and pouring it slowly over the nipple. might help.
    if not the brake resiovoir is clear plastic at a think on top left of bulkhead
    Feb 2011
    bedfordshire
    Thats how I got the hand brake cable lug off the caliper when it was jammed on
  1. Bleed nipple size
    By dilan in forum Suspension, Wheels & Brakes
    Last Post: 7th November 2012, 13:41
  2. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  3. Rear brake caliper bleed nipple
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 18:45
  4. Is this a leaking brake fluid bleed nipple ?? (pics)
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2007, 20:10
corsa C rear bleed nipples
