Thread: Cruise Control no longer working..
    Jul 2010
    Yorkshire
    Default Cruise Control no longer working..
    Hi,
    My car has been laid up for a while. I've just taken it to the garage to have a new timing belt, water pump and aux belt fitted (not sure if its ever been done in its 71k miles! - 3.2 engine).
    Anyway, when the car was in use the cruise control would work, and then after so long, stop working (wouldn't re-engage). If I turned the car off, left it a minute and then re-started it, the cruise control would work again.
    Since the car has been laid up, I've come to use the cruise control today and its not worked. The light doesn't flash up and the cruise doesn't engage.
    Is there anything that I can look at to try and get this working?
    Thanks.
    Jul 2010
    Yorkshire
    Forgot to mention, the car is an Auto.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The actual stalk that the CC is on can wear at the end. Try pulling the stalk towards the passenger whist engaging the CC. If it works when you do this theres a how2 on how2 solve this issue. You could also try removing the stalk and cleaning the connections on the end too.
    Jul 2010
    Yorkshire
    Thanks Das, I'll have a look when I get the car back from the garage!
    Jul 2010
    Yorkshire
    I've just picked the car up. Cruise worked first time of asking, then stopped.
    I then stopped the car later on my journey home, turned it off, re-started it and it worked each time.
    Pulling the stalk made no difference.
    Confused?
    Woodbridge
    Mine is not working either, but I think mine is the clutch spring, not sure how that would work on an auto though.
  1. cruise control not working
    By nick6515 in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 20:05
  2. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  3. Cruise control not working?
    By cjporter in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 16:10
  4. Cruise control not working
    By tommyk999 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2008, 11:13
  5. Cruise Control not working
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 21:13
