Results 1 to 10 of 14
Thread: Top Tips for Turbo's
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    Default Top Tips for Turbo's
    Hi all, I just wondered if anyone out there has some top tips/common sense comments regarding prolonging the life of you turbo and generally being nice to it to get the most out of it - when to blast it, when not too etc etc....
    Some people are new to Turbo's and thought it may help.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    As a rule of thumb, let it idle for a minute or two before and after a journey, and don't give it the beans while its cold - usually give it 5-10 mins before unleashing the boost
    ...and don't rev it just as its turned off either, as I have seen many people do
    Regular Member Jezzy's Avatar
    S.E
    Change the oil often, and use the best quality oil you can afford. That's good advice for any engine, but it applies doubly so to the turbo. On cars where oil changes have been neglected, the turbo will probably suffer sooner than the block/head.
    wylam
    the dealer told me to let it idle for about 20 secs before you turn the ignition off after a journey
    Sodding Typical on Sea
    As the others say, be gentle when it's cold to allow oil to fully circulate and gain some heat, regular oil changes especially so in hi-pressure applications and a short 60 second cool down at idle after it has had a fast run is always an extra precaution worth observing IMHO.
    Regular Member Innes's Avatar
    Plymouth
    Defiantly give it 20 secs or so after a short journey. If you do a long motorway journey I would advise a few minutes. The owner of a garage I go to actually takes it out of gear a mile before he's coming off at a service station and coasts it to the slip road then lets it idle fore a couple of mins before switching it off! I wished I had know about this when I bought my first turbo diesel (Renault Megane - good riddance!) as I went to gatwick from plymouth and just switched it off when I got there. After a nice 2 week holiday I started the car and got a nice grating noise from the turbo as I pulled away. £££££££
    spoons
    Guest
    I disagree with that, you need to drive off as immediately as you can from starting the engine to allow oil pressure to build and coat the parts. Not race off, just drive off normally and keep the revs down below 2500 - 3000 rpm
    You can hang around all you like when to finish your journey.
    Agree with this, but make sure you have measured the oil on the dip stick when its hot - not cold. Cold will show a lower reading and overfilling the engine with oil once its hot can create more pressure and blow oil past the turbo seals.
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by spoons View Post
    Not for me, agree that excessive idling isn't recommended due to the oil pressure being at its lowest, but as for setting off as soon as you start, not for me.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I always let it idel of a minute to warm up, then I keep the revs below 2000rpm and only accelerate gently until the coolant reaches operating temp or 80-85 Deg.
    wylam
    i drive 9 miles to work and by the time i get to work its just reaching 85 deg,which is where the temp gauge always settles at,so i sit 10 or 20 secs letting it tick over.
  1. Turbo's off again
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2011, 16:49
  2. A question of Turbo's
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 12th May 2011, 20:57
  3. Turbo's knackered
    By ian mc in forum Engine & Drivetrain
    Last Post: 24th June 2009, 22:18
  4. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  5. Turbo's
    By SteveH in forum Diesel Engine related
    Last Post: 9th October 2006, 10:19
