Thread: No Boost/Irregular Boost
    Middlesbrough
    Default No Boost/Irregular Boost
    First question is could this be caused by the swirl flap linkage rod or the valves being blocked?
    Looking at the bar it appears to be laid on its side and has quite a lot of play in it up and down but still seems attached I assume this is not good.
    I do need to check if the car has a DPF as I am unsure. I have also cleaned the EGR and the boost sensor recently.
    This problem is driving me mad and I can't seem to fix it the turbo kicks in sometimes but not others and when it does it drops off altogether after just 1000 revs with a tug back on the car.
    Finally while accelerating in 4th last night the car just stopped accelerating alltogether, spanner light came on and couldnt go any faster with foot to the floor than i already was. This has now gone off again.
    Any suggestions or help is much appreciated
    Regular Member Innes's Avatar
    Plymouth
    Have you checcked your vacuum pipes?
    Middlesbrough
    No where are these located exactly?
    This could be a possibility as I have just had timing belt done along with clutch and flywheel so the cars been in bits
    Plymouth
    They are easy to get to. Here is a thread about it.
    http://www.vectra-c.com/forum/showthread.php?t=109454
    You can buy silicone replacement pipes off ebay.
    http://cgi.ebay.co.uk/4mm-BLACK-SILI...item43a58d8a52
    Middlesbrough
    Was exactly that, temporary fix till I can get some new pipe and the car goes like new again.
    Thanks for the help
    Plymouth
    Great. Glad I could help :-)
  1. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
