Results 1 to 10 of 22
Thread: Creaking/clunking from front suspension after bilstein & eibach upgrade
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Default Creaking/clunking from front suspension after bilstein & eibach upgrade
    As title, it's been a week since I did the upgrade. Whilst I was at it, I changed the front & rear drop links.
    Just been to Glasgow this weekend and pulled into a services on the M6 about an hour into the journey, and noticed this creaking/growning and clunking from the driver's side front. Sounded a bit like a frog croaking...but really loud.
    Has done it all weekend, but it doesn't do it at first...seems to take a while of driving to trigger it.
    Any ideas on whether it is the top mounts or the ARB bushes?
    Any way of finding out which bushes are fitted, other than climbing under the car?
    Cheers in advance guys!
    Regular Member kevcdti's Avatar
    North east
    Mine has the same sort of frog sound on same side and mines the strut top bearing
    WGAF#5
    indeed as Kev has said when you fitted the new suspension did you replace the top mounts and bearings as well .... it would have been worth the extra money as you could have built up the front legs and just bolted them on ....i suspect that the bearings are worn/dry and thats the cause of the noise
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Yeah I have to admit to not bothering with changing the bearings and top mounts...
    So, do I really need to change the mounts, or can I get away with just changing the bearings? There didn't seem to be anything wrong with the mounts when I had it all in bits...
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Anyone else with an '07 CDTI SRi that have changed their ARB bushes that can say which size is fitted to our cars?
    East Midlands
    Cant see it being the top strut bearings in all honesty,as they tend to show up when your turning the steering wheel at slow speeds,there is a test you can do ..get some one to turn the steering wheel while you put your hand on top of the mountif its goosed you'l feel it through your hand...?Did you tighten the top mount nuts up ,silly question i know but does happen..failing that look at changing the ARBs.
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Iv just changed my arb bushes on a 56 plate and they was the 25.5mm ones I was quizin the manage in my stealers he said u can get a crocking noise for arb bushes!
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by macdad View Post
    Yeah I tightened the nuts up pretty tight...
    Quote Originally Posted by keith150882 View Post
    Cheers fella, now I can order some replacements. Have also ordered a bearing just in case.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    OK, I've ordered a full set of front and rear ARB bushes and a top mount bearing. Hopefully that lot will sort out the noise!
    Rear ARB bushes here
    Front ARB bushes here
    Top mount bearing here
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Did you fit the lower spring sleeves when you fitted the springs?
  1. Creaking front suspension struts
    By bobsimes in forum Suspension, Wheels & Brakes
    Last Post: 25th April 2012, 09:01
  2. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  3. clunking noise from front suspension
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2011, 23:21
  4. Creaking front suspension over speed bumps.
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2011, 15:23
  5. Creaking front suspension
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2009, 17:54
vectra c clunking sound when steering
what type of bearing is used on corsa c strut top
vectra c front springs keep clunking
bmw bilstein spring creaking
corsa c front strut top bearing
vectra c creaking front suspension
signum cdti 150 bilsteineibach
