Thread: Win-ce hack for double din units?
    Liverpool
    Default Win-ce hack for double din units?
    Right this is a long shot but.......
    after a conversation with a mate in work, i have found out that most of the chinese double din units run using wince
    he has downloaded a patch for his unit, which is similar to mine, which unlocks wince and the unit can be used like a car pc and the 'skins' can also be modified plus things like an ipod theme etc
    i was just wondering if anyone has had any dealing with these hack's
    this might be one for yysnet!!
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Well...I done it on mine...
    Wince is a good system for embedded processors, and can be as small as some hundred K bytes or as large as some hundred M bytes depending on requirement. A basic CE system is just provide basic support and a full CE works like windows 9x.
    So whether you can "crack" is really depending how they customized the system, i.e. how integraty your system is. If the system is without the necessary support for desktop, then no crack will work.
    The crack/patch normally is tool to activate your desktop. If you know windows system well, then you know the desktop is an windows application call explorer.exe
    To crack your wince car unit, first thing need to know is the way they hide the desktop. Some of them just hide it by alter the registry, some of them by replace explorer.exe(desktop) with their GUI application, and some put the GUI to the startup progress and the GUI will cover/kill the desktop when loaded.
    But if you dont want to know these, then it's worth to try that crack. But some unit can't easily save the configuration.(i.e. it will back to original system when restarted) this is not like WM systems in smart phone.
    For my wince system, it's a sererate unit that uses CID as display. I just wrote an interface to choose between IGO and TOMTOM and some small tools and games, rather than make it a fancy carpc...
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    I'm also very interested in this...
    how do i know if i have windows CE 5?
    i have a xtrons td714 which i was told runs CE, just have no idea how to access it
    Regular Member i5aces's Avatar
    andover
    My pioneer is windows based. I just downloaded a file that boots it into test mode and therefore windows. From there you can change almost anything.
    Liverpool
    Quote Originally Posted by yysnet View Post
    Thanks for the info!!!
    To be honest I just want it to be able to amend the skins, and also use it as a desktop for browsing files and possibly accessing the internet via tethering.
    There is a guy from the golf mk5 & m3 forums who has written alot of cracks (costing $19.99) which will unlock everythin but I have seen some free files which can do the jobs I want for free at the moment, then if I do use it more I will buy the better crack and files
    I'll keep you posted about how I get on
    Liverpool
    tried a free hack WOLFncu
    and well its bit ****! no skins load up correctly, and the skin only works after booting up the hacks exe file, nothing changes unless this is booted up and nothing is loaded onto the internal memory
    plus i couldnt assign my sat nav .exe file to the new 'nav' button on the screen, so after loading the new hack/skin i couldnt even access my nav
    so i might be forking out $19.99 to try out some proper software from here
    http://www.flydigital.ro/wince/
    unless anyone else has other ideas?
    idealy i would like to change my normal unit skins, but as these units tend to use 2 boards/drives i probably cant
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    what stereo is it i looked on ebay but all i can find are the astra ones were it comes forward on the trim
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    yysnet. You got TomTom for winCE, I looked everywhere for it but could not find it was proper gutted read on there website the stop supporting it and no longer sell the software, so ended up with iGo8.
    Paul_sri150, did you manage to find anything out about the hack, I had a read on that webpage you linked to, but I do not know what the hack will do. I wouldn't mind being able to add custom "car logos" to my unit, the standard ones are plain boring IMHO.
    Regards
    Dave
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    i think something like "miopocket" could work for you - it is an unlock suite for many wince 5/6 based gps receivers, and may work for you. google miopocket!
    (i would love to be able to attach a canbus interface and do all sorts of cool panels and engine management and tech2-programming from the ICE touch screen, but hey thats just dreams)
  1. The Daily Hack Derv....
    By Vectra Adz in forum General Motoring Chat
    Last Post: 11th July 2012, 18:47
  2. Pioneer or JVC Double Din? 2 Units to pick
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 23:19
  3. SONY Playstation Hack...
    By spoons in forum Games Room
    Last Post: 28th April 2011, 11:25
  4. Does this hack anyone else off?
    By purple170503 in forum General Chat
    Last Post: 10th April 2010, 14:16
  5. Show me your double din sat nav head units......
    By PAULMAC77 in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2009, 17:01
chinese double din hack
chinese double din radio hack
wince radio hackwince patch for chinese head unitunlock china car radio windowsxtrons pf70fsf-b hackwindows ce chinese double dinenable wince explorer in car unitxtrons win ce updatedouble din radio hackhacking chinese wince radioxtrons windows ce 6.0xtrons hack windows ce 6.0hack car stereo windows cewindows ce radio hackwince double dinwindows ce 5.0 Car stereohackwindows ce 5.0 Car stereo desktop2 din mp5 hackautoradio op windows ce hackhead unit hack cewin ce download for xtronhacking windows ce car stereowince 2din car hackingwince patch 2din
