Results 1 to 10 of 15
Thread: Vectra C 150 CDTi Lack of Power
    Mar 2011
    Barnsley
    Default Vectra C 150 CDTi Lack of Power
    Hiya,
    I bought a Vectra C 150 CDTI yesterday and having driven it i have now noticed that it seems to lack power below 2250rpm, any ideas/common faults ???
    Many Thanks
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Take the engine vanity cover off and have a look down behind the fuel rail. You will see a metal rod. If it is lying there or has become detached then the manifold is needing replaced - common fault. If the rod is attached don't touch. I wouldn't be surprised you find lots of oil sweat there anyway.
    Other possibility is the EGR valve which inhibits power under 2,000rpm.
    Gazza4
    Sep 2009
    middlesbrough
    Remove and clean your egr valve and your boost sensor, have a look in the how 2
    Mar 2011
    S
    Get the EGR valve cleaned. I had 1.9cdti SRI 150 and was losing power until finally it wouldnt go above 10mph!! Was a clogged up EGR valve.
    Mar 2011
    Barnsley
    engine cover removed, and the metal rod is just lying there, not attached at all, does this now mean a new inlet manifold ????
    West
    you can bodge it up for a while, i think there's a howto... but yes you need a new manifold
    Regular Member ROY GBIV's Avatar
    The highways and byways
    Quote Originally Posted by sclarkson82 View Post
    So the rod is off but the only effect is that the car is lacking power below 2500rpm?
    Mar 2011
    Barnsley
    seems to be, why wats else cud there be, like i said not had car long
    Nah, I was under the impression that if this failed the effect would be more noticable and catastrophic than a lack of power low down the rev range.
    I'm new to the 'C' as well. Knowing my luck mine has probably detached itself too!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mt missus' car was like this. The swirl valves were stuck solid. Managed to push them into the "open" position for now, leaving the rod off (no oil sweat though). Number 3 still moves freely (motorised one?). The car runs fine, and pulls like a train, right through the rev range. Inlet manifold is my next job, though
    It was a little rough until I cleaned the EGR valve and boost sensor.
  1. 3.0 v6 cdti 2004 lack of power
    By DONNAS5889 in forum Engine & Drivetrain
    Last Post: 15th June 2011, 20:58
  2. Cdti lack of power engine sluggish
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 19th January 2011, 16:07
  3. Help needed Lack of Low Down Power cDTI 150
    By supersione in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2010, 19:58
  4. Lack Of Power (2004 1.9 cdti 8V)
    By user999998 in forum Engine & Drivetrain
    Last Post: 2nd June 2009, 09:03
  5. cdti 150 lack of power
    By michael cummings in forum Diesel Engine related
    Last Post: 8th February 2009, 20:44
vectra c 1.9 cdti lack of power
