Thread: passenger seat jammed right back on runners and wont budge!
    essex
    Unhappy passenger seat jammed right back on runners and wont budge!
    Hi
    Last week my misses moved my passenger seat back using the lever at the front and now its stuck there and wont budge
    I cant find anything jammed underneath and cant find any reason for it bein stuck!!
    Wondered if anyone had any ideas
    cheers rich
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    try lifting it up a bit on the hight adjuster lever on side
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    this happened to me a few weeks back, just check that the cable hasn't come of the lever underneath the seat that allows it to slide backwards and forwards. i.e get you misses to operate the lever and get your head under the seat to see if you can see anything operating. if the cable has popped out you will see straight away just clip it back in and job done hope this helps.
    Regular Member mccluskey119's Avatar
    gourock
    I have the same problem the wires r connected but still the seat.won't budge? Any more suggestions ?
    I've tried lifting, being gentle and a little brute force lol
    May 2008
    Tyneside
    If the inner wire is connected at each end, then the outer sheath might have been dislodged under the seat.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i,m having trouble with this in the tigra...seat just aint budging ...
    Sep 2010
    worcester
    twist the bar underneath forward if i remember rightly while pushing the seat....
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by soulman View Post
    Seems to be a bit of an epidemic.
    6 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by leedavis View Post
    not so easy to do in a Tigra ...but will try ....
  1. Front Passenger Seat Belt Jammed
    By smoggie in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 16:28
  2. Passenger seat wont move!!!
    By edwardabud86 in forum Bodywork & Interior
    Last Post: 27th May 2011, 06:58
  3. Jammed passenger seat
    By toghermi in forum Bodywork & Interior
    Last Post: 14th June 2009, 10:22
  4. Passenger front seat jammed
    By Darryl2.2DTI in forum Bodywork & Interior
    Last Post: 12th April 2008, 09:44
  5. Help..indicators wont budge!
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 20:12
vauxhall corsa seat lever stuck
vauxhall corsa front seat stuck
Corsa c seat jammed wont slide
corsa seat stuck
corsa car seat stuck
corsa passenger seat stuck
vauxhall insignia passenger seat stuck
vauxhall corsa seat problems
my ford connect passenger seat back is jammed
stuck car seat vorsa
insignia passenger seat jammed
ford mondeo drivers seat runners jamming
corsa d passenger seat wont move
vectra c passenger seat stuck
My 2011 vauxhall corsa passenger seat is stuck on slider
ford focus passenger seat stuck
vectra seat jammed
corsa seats jammed
vauxhall corsa passenger seat stuck
front seat stuk vectra c
2014 corsa front chair move
why wont my front seats move fowatf or back on my vectra c
vauxhall corsa seat jammeed
vauxhall corsa seat runner jammed
