Results 1 to 10 of 18
Thread: V6 CDTi pulls like a rubberband
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Default V6 CDTi pulls like a rubberband
    Hi
    I have just changes the turbocharger on my V6 CDTi. It was drinking oil. I then have a spare engine which has covered 60.000 miles where there is a turbo attached. The engine that I have in spare has a timebelt damage, so no damage on the turbo.
    After 6 hour fitting the turbo the engine was spinning again. But it now feels like it´s being pulled with a rubberband attached. This only shows when I floor it.
    No spannerlight at all. Starts perfect and dosen´t smoke as much as the old turbo did. It also pulls like is should beside the feeling of being pulled in a rubberband.
    Even my wife looked at me and said "what´s that??" when we were both on a drive.
    Does anyone know what could be the issue.
    LMF?
    Boost sensor?
    Injectors?
    anything else???
    Would appreciate any answer.
    Thanks lads...
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    I´ve just read in another thread that is could be blocked SCV´s
    When the engine just is startet it sometimes drops in revs and goes up to normal revs again...
    I can hear a little high noise when flooring it. It goes up and down in sound when flooring it. It´s also very notisable when you put the window down when flooring it.. also at even speed it goes up and dowun in sound and pulling.
    could it be SCV´s
    Quote Originally Posted by Hummelshøj View Post
    That sounds like the turbo is switching on/off/on/off/on/off
    This is a symptom of a blocked SCV
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Ok I thought so...
    Then I have to book time at OP and let them check it for it.
    Very strange it should come after changing the turbocharger... or maybe not.. I don´t know...
    If dirt has got into the fuel system, then it eventually ends up at the SCVs, accumulates and blocks it
    Finding a mechanic with experience of the Isuzu engine will greatly help
    Middlesbrough
    Im having similar issue on my 1.9CDTI [150] the turbo kicks in sometimes but not others then in 1st and 2nd then in the higher gears I can hear it spooling up then it drops off and there is a slight tug back.
    Does this sound like a symptom of blocked SCV's and also what are SCV's?
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    SCV stands for Suction Control Valve and is placed in the fuel pump...
    Could some injector cleaner such as BellAdd, Redexx or simular maybe help losen the dirt and clean the valve. Or is it "done" if the dirt hits the valve...
    I also read that changing fuelfilter maybe could do the work. t could be blocked or very dirty...
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Just checked when the fuel filter was changed...
    7. Oct 2010 at 181.700km ~ 113.500 miles. The car has now covered 195.000km ~ 122.000 miles... so approx 10.000 miles...
    Middlesbrough
    My problem has got worse since I changed my fuel filter
    Quote Originally Posted by Seery_SRI View Post
    Im having similar issue on my 1.9CDTI [150] Does this sound like a symptom of blocked SCV's and also what are SCV's?
    It could be, I've never heard of blocked SCVs on this engine
    SCV - Suction Control Valve
    Diesel engines have these to determine how much fuel is required between the fuel pump and inlet valve, and to prevent back pressure
    Normally there is one per cylinder
    However, in car engines they are mounted as part of the fuel pump, so can be reduced in number so are typically one in four cylinder, two in a six cylinder, and so on
  1. Illuminating the interior door pulls?
    Last Post: 2nd November 2014, 21:52
  2. pulls like a train above 2000rpm but??
    By Gerdo3 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 20:56
  3. Car pulls to the left
    By ScottR in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 10:15
  4. 1.9 cdti pulls right on acceleration. normal?
    By MCD in forum Engine & Drivetrain
    Last Post: 1st March 2009, 19:28
  5. can anyone help? car pulls to the left
    By kev bux in forum Handling & Braking
    Last Post: 30th July 2007, 12:37
