Thread: cruise control broken!
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    Angry cruise control broken!
    Hi all, looing for help!
    cruise conntrol is on the blink, when i click it the green dial appears on the dash for a fraction of a second, and then goes off......
    cleaned the stalk... no joy
    replaced stalk... no joy
    i have seen that there is an issue with the switch under the clutch.brake pedal breaking, however i cant see it been that, as it wouldnt come on at all.....
    i plugged the car into some diagnosis software. got the following codes
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    B3794 - Switch Cruise Control Circuit Open or High Voltage
    (04) - Not present
    any ideas???????????????????? thanks
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    When you set it try lifting the pedal with your foot just to eliminate spring doesn't eliminate dodgy switch though
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    When my Cruise Control kept going off, I was told it registered a 'Circuit Malfunction Error' ; it turned out to be the CIM, though I was told it could have been the Clutch Switch. My Clutch Switch got replaced, but that did not cure the problem, replacing the CIM did.
    Jan 2008
    leeds / wakefield
    ye tried the lifting the pedal up, bo joy there im afraid. hoping that its not the CIM! going to check all the fuses shortly....
    Jan 2008
    leeds / wakefield
    just replaced the clutch spring.... still not working :-(
  1. Cruise control
    By br4duk in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2011, 15:22
  2. Cruise control ?
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 6th May 2009, 18:39
  3. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2008, 23:27
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. cruise control
    By wxmlad in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2006, 01:46
b3794-08 vectra c
b3794 hiba
b3794
b3794-08
vectra c b3794
greška b3794-08
