Thread: Electronic Warning Light after Engine rebuild
    Oct 2010
    Cheshire
    Default Electronic Warning Light after Engine rebuild
    Just wondering if anyone can shed any light on the problem I have on my Signum 2.2 Direct 54 reg Petrol.
    Back in Nov 2010 the swirl flaps in my inlet manifold went into the engine and caused £1500 worth of damage. (Replaced Rocker Arms, Inlet valves, ball studs, timing chain and Head bolt and gasket sets)
    Since its been fixed we have not been able to afford to run the car and now sits on the drive. We have started it nearly every week but occasionally it's been every 2 weeks. Then on Tuesday the car would not start, initially we thought as it had not been started for a while we thought the battery was flat, so we jump started it and it ran fine. Then today had to jump start it again. After leaving it on the drive for a while the Electronic Warning light came on (Car with Vertical spanner) I read the manual and switched the car off and then started it up again to see if it disappeared, it did then came on again and the 10 seconds after the car went dead. Started it again and did the same.
    Has anyone got any ideas as to what it might be????
    Aug 2009
    herts
    Alternator my guess.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    op com or similar to read stored codes will give you the answer.
    Regular Member Mopar Man's Avatar
    herts
    Need to read codes.
    Has all 2.2 petrols got swirl flaps?
  1. Warning light - little pic of an engine
    By ian1963 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2010, 17:20
  2. engine warning light
    By spooney in forum Petrol Engine related
    Last Post: 20th January 2009, 18:05
  3. electronic warning light
    By petersaxon in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2008, 16:29
  4. Engine Warning Light
    By harveyg77 in forum Engine & Drivetrain
    Last Post: 5th June 2008, 20:35
