Thread: Possible to clean the erg on a z16se astra?
    Regular Member Craig1985's Avatar
    harwich essex
    Default Possible to clean the erg on a z16se astra?
    As above, why I ask is because the erg looks nothing like my z19dth one?
    Problems she Is having with the car is juddering when accelerating under 2k. Fault codes listed are erg and crankshaft sensor my rpm signal? Would you say the juddering is more likely going to be the crankshaft sensor problem as I thought erg would just make it sluggish?
    Jul 2009
    The Rift, Cardiff
    The egr is a sealed canister type and tends not to soot up like the diesel ones. My old one had rusted and was leaking and sucking air and caused the eml to come on, the car to run rich and rough idle. It's the same one as on the 1.8 z18xe vec c and a few other engines;
    Astra G & Zafira 98-05 - Z14XE, Z16XE, Z16SE, Z16YNG, X16SZR & X18XE1
    Corsa C 01-06 - Z14XE, Z16SE & Z18XE
    Meriva 03-> - Z16SE, Z16XE & Z18XE
    Tigra B 04-> - Z18XE
    Vectra B 96-01 - Y16XE, Z16XE & X18XE1
    Vectra C 02-> - Z16XE, Z18XE & Z18XEL
    harwich essex
    So there is nothing I can do to try clean/ free up the old valve then? She said she had it replaced 18 months ago?
    Jul 2009
    The Rift, Cardiff
    There's no harm in cleaning what you can and putting a bit of copper grease around the solenoid. To check if its leaking spray some carb cleaner on it while the engine is running, if it changes the idle its leaking/sucking.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    there is a cure for this blanking gasjet for egr check with tech 2 to see if egr voltage is below 1.2v then reprogram ecu to delete egr function
    harwich essex
    So if the voltage is below 1.2v then I can blank it, but if it's more then I need tech2 to delete the egr function? My friend has vaux-com and when doing a output test you can here it clicking when open and closes?
  1. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  2. Astra G, Z16SE help required
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 13:55
  3. Clean the car
    By amiddleton in forum General Chat
    Last Post: 22nd April 2009, 19:09
  4. My dirty then clean Astra!
    By Jim Bob in forum Non Vectra C/Signum Album
    Last Post: 17th January 2009, 17:00
  5. 5th Gear - 888 Astra vs Astra VXR
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2006, 00:26
astra z14xe judder
16 Z1.6 SE
