Thread: Multimeter setting for power drain?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Default Multimeter setting for power drain?
    Evening all. The other halfs Punto is is having some problems at the moment (yes I know its a Fiat and it comes with the territory), could anyone tell me the setting on my multimeter to use to find a power drain in a circuit. I was planning to lock the car, pull 1 fuse at a time and put the meter across the contacts to identify the individual circuit.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    A car is 12v DC so the setting should be anything over 12 with the symbol v- not v~ as this means alternating current (spelling not that good).
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Personally I'd set it a bit under 12V, as a power drain could just be a trickle, hard to be sure of a small reading on a big setting.
    Ashington, Northumberland
    You are checking for current drawn,so you should have it set on the 'amps' setting. Also, the best way to check is to take off the battery pos lead and put the multimeter between the lead clamp and the battery pos terminal (making sure the two don't come together). Then pull one fuse at a time. Setting it on the voltage setting won't give you any results
    Regular Member hagga's Avatar
    kingswinford
    As Gary says, you're looking for current being drawn... make sure you turn everything off, set it to highest DC Amps setting and make sure leads arein the correct terminals (most multimeters will do 10A)then pull your fuses one by one.. you may want to turn off your interior light if you need doors open to access fuses as this could throw a red herring in the works when you pull that fuse.I presume that you've checked the battery/alterator are good? oh and make sure you swap leads/set meter back to DCVolts before any voltage checks or you'll blow the interal fuse in the meter
    Nov 2009
    Lancashire
    What the last two said.
    You'll usually have to move the red meter lead to a separate socket too to use the 10A range.
    Remove the +ve clamp off the battery and connect the meter leads between it and the battery terminal.
    Do NOT try and start the car though! You will fry your meter!
    (Checking current drain on the Vectra is quite interesting as you see the different circuits going to 'sleep' as the car shuts down.)
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    as its a fiat I would be inclined to clean all the earths around the car first think there is one on the rear inner arch and one in engine bay plus the earth strap engine to body
    Vehicle : SRi
    Mileage : 110000
    Thanks for all that guys, it just what i'm after Its deffo not the battery or alternator, as they've both been checked. We can charge the battery put it in th car and within 3 days without driving it the car wont start. You turn the key, the engine turns over slowly, the alarm chirps (like when you disconnect it) and the dash resets itself.
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Ya sure the altenators ok? If you put the meter across the battery terminals it should read over 13-14v when engine running
    Justin
    Aug 2010
    Luton
    Quote Originally Posted by westonprawn View Post
    Justin
    he says it will go flat without using it so its not alternator
  1. What multimeter
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2013, 23:30
  2. Multimeter
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 21:03
  3. How to drain power steering fluid?
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 18:41
  4. can anyone recommend a multimeter?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 13:38
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
