Thread: B1330 - System Voltage Malfunction
    Mar 2011
    essex
    Default B1330 - System Voltage Malfunction
    (00) - Present
    In PDM and DDM.Any ideas?could it be programming the module?
    And battery drain. amps jumping up and down from 0.25 to 0.95.drains the battery in a week.Lights have a reaction to revs on low revs.
    Tried to remove fuses one by one no changes.New battery,new alternator no luck
    Nov 2009
    Lancashire
    B1330 - Passenger Door Ajar Circuit Short To Ground ?
    Mar 2011
    essex
    Thanks for your replay Graham.
    But what does that mean?What exactly I should do?
    I'm sorry I'm not good in these things.
    Thank you for help
    May 2007
    Norway
    Did a quick google on the faultcode, and it shows:
    DTC B1330 Left A/C Discharge Sensor Fault
    (On GM-cars....)
  1. P0400 - EGR Flow Malfunction
    By BigMart in forum Engine & Drivetrain
    Last Post: 30th May 2011, 22:07
  2. B1330 - System Voltage MalfunctionB1330
    By black sri1.8 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2011, 19:08
  3. P0560 - System Voltage Low Input
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 18:05
  4. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
  5. Fuel trim malfunction
    By tommyk999 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 15:32
Vauxhall B1330
