Results 1 to 10 of 16
Thread: Petrol in a Diesel
    stoke
    Default Petrol in a Diesel
    Not a vectra question, but I trust you guys.
    My friend has recently put Petrol in his Diesel x-type Jag and was wondering if we filled the rest of the tank with diesel.... (He put about 9 Litre's in the tank) would it be ok...
    The AA want to charge £180 to sort it out WITH road assistance cover.
    which I believe is a wee bit steep!
    Mar 2011
    kent
    i would at least empty the fuel tank of all fuel and he might have a chance also depends on how far he drove it after fuel mistake
    Ashington, Northumberland
    If you fill it up to the top you should be ok. It is best practice to drain it, and if been ran, then flush the fuel lines and change the filter, but if its not been run then just fill up with diesel. It may be smoky for a while. Keep the tank topped up too, ie when it gets down to 3/4 full, top up to full again. do this about 4 times and it will be fine.
    Sodding Typical on Sea
    Petrol will dilute well in a ratio of about 6:1 with no long term damage to fuel pump and seals, but add some black Redex as well IMHO
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    Quote Originally Posted by Derek Mc View Post
    should be ok we used to add petrol to lorries before a PSV test to reduce smoke and emmisions
    This week we had a coach fill up with unleaded instead of diesel
    The pump cutoff at 100 litres and it was only then that the driver noticed
    The coach had to be towed away, it returned the following day to be completely filled up
    How to waste £140 of petrol!
    Quote Originally Posted by peadar View Post
    Me too back in the day to stop the diesel waxing and blocking the filters
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    if he put 9 litres in make sure he puts a minimum of 50 litres diesel in should dilute the petrol enough
    far safer todrain though
    Feb 2011
    IN A HOUSE
    well i did the same last week in my vec, i already had half a tank but thought id top it up, then like a T%*T I put £6.53 worth of petrol in it before i realised i was in my own car not my works car so stopped immediatly - paid for the petrol and then went back to neck it with diesel - shook it up a little round a few bends and its been ok since.
    Regular Member Mopar Man's Avatar
    herts
    9 litres
    I wouldn't chance that much, May cause the engine to Knock....
    I have found that petrol floats on top of diesel.
    Be on the safe side. Expensive mistake otherwise.
  1. petrol or diesel
    By kram1000 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2011, 15:10
  2. Petrol in Diesel!
    By P-Mutton2.2 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2009, 06:53
  3. PETROL vs DIESEL?
    By vectrahuw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 00:07
  4. Diesel and Petrol
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 22:29
  5. Petrol vs Diesel
    By kryton01 in forum Diesel Engine related
    Last Post: 14th September 2006, 06:49
