Thread: Rear brake caliper bleed nipple
    Feb 2011
    bedfordshire
    Red face Rear brake caliper bleed nipple
    Hi Guys,
    I have just ruined the thread of the bleed nipple when doing the rear brakes on my 1.8 club, well I'm hoping its just the thread on the nipple and not the calliper. Does anyone know where I can get a nipple to check and if it is the calliper where a good place to get one from might be?
    Thanks, Tony
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Yes you have another one on other wheel.... use that to see if its just the nipple but if you have the nipple off then you should see the thread on the nipple and know if its damaged.
    Feb 2011
    bedfordshire
    Thanks. I had another look and the nipple thread seems fine but has metal inbetween the threads which I can only assume is the thread from the calliper
    Do you know know where I could get e reconditioned calliper sent from? I have been looking online but recommended sellers are always preferred.
    Nov 2009
    Lancashire
    Could you get a slightly larger one and re-tap the caliper thread to fit it?
    Sorry, not a nipple expert LOL.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Not taking the kudos for this one but new nipples are
    Quote Originally Posted by lizard View Post
    10mm and the pitch is 1mm
    http://cgi.ebay.co.uk/10mm-x-1mm-Met...2#ht_500wt_715
    Feb 2011
    bedfordshire
    Thanks for the link DasArab. I'll order those and see if there's enough of the existing thread in the calliper to use. Otherwise re-boring to another size, perhaps 11-12mm could be done if the thread in the calliper is shot. Thanks for the suggestion Graham.
    Thanks for your help guys, I'll post later and let you know how I get on :-)
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    I would think caliper is ok its the nipples that are quite soft lol just try to clean the thread out before fitting new one might be best done on a bench
    scotland
    as said before the nipple is made from softer metal so should go first . run a 10mm tap up it then use new nipple it should be fine just dont over tighten it .
    Feb 2011
    bedfordshire
    I have ordered new nipples but as half the thread is missing in the caliper I will try re-threading it first. Failing that a new (well, recon/secondhand) caliper it will have to be.
    Also do you know where I can get the correct rewind adaptor? I have a 3/8 rewind tool and bought 2 adaptors but they don't fit. I have been looking online but cant find one listed for the Vectra, all the vauxhall ones listed seem to be for the Vectra B
    Feb 2011
    bedfordshire
    The adaptor for the Vectra C is different from other Veccy and is the same as a SAAB 9-3 So just in case anyone else has as much trouble finding the correct tool as I did the correct adaptor is a Laser 3104 No.7. I got it from here. . .
    http://www.avenue35.co.uk/shopping/p...or-No-7/?bc=no
    But have seen it on ebay and other places.
    Hope this helps
  1. Has anyone ever replaced a caliper bleed nipple?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2014, 00:00
  2. seized rear calliper bleed nipple
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2012, 23:36
  3. Help - cannot get brake shoe piston back in, cant open bleed nipple
    By JACKALG1 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 14:25
  4. Is this a leaking brake fluid bleed nipple ?? (pics)
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2007, 20:10
what size is the bleed nipple on rear caliper on vectra b 2.2 sri
vectra c bleeding brakes
vauxhall vectra c brake bleed size
signum brake bleed nipple
bleeding screw for zafira a 1.8 rear breaks dimensions
bleed nipple for vauxhall vectra
vauxhall brake nipples
vectra c bleed nipples
brake bleed nipple sizes vauxhall
o3 vectra brake bleed nipple size
What size bleed nipple for vectra c rear brake caliper
how to replace bleeding nippel vectra b
vauxhall vectra bleed nipples
where is the brake nipple on a vauxhall insignia
what size are Vauxhall brake bleed screws
brake bleeding tool for vauxhall vectra c
bleeding rear brakes vectra c
vectra c rear brake nipple
vectra c bleed nipple size
