Results 1 to 10 of 18
Thread: spring sleeve mod
    london
    Default spring sleeve mod
    Hi folks-just wondered if when doing the spring sleeve mod is it possible to compress the springs enough - while still in situ to simply do the sping mod sleeves as it would save having to take everything out too!!
    ?? was thinking in must be doable with 2 compressors on each spring at one time as it only needs to be compressed far and long enough to slide the sleeve on?? any advice would be handy ;-)
    in a house
    whats a spring sleeve mod?????
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    I would think it would be far easier to drop the strut out, fitted my springs the other week and put new plastic sleeves on, If you can compress em far enough while on it might be possible but a faff. Give it a try, if not your half way to taking it out anyway lol
    Regular Member Jezzy's Avatar
    S.E
    You'll struggle to get the spring compressors in place with the strut still on the car.
    london
    anyone tried and managed it though?? and how long would it take including dropping the struts down???
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    would think about 3 hours see struts removed springs replaced/ mod done rebuilt and ready for a road test
    S.E
    You won't need to remove the springs, just remove the strut, raise the spring off the bottom seat using the spring compressors, slide the sleeve on and then remove the compressors and refit the strut.
    Aug 2010
    Luton
    ok is this spring mod just plastic wrap then? do they not wear out after about 2 weeks?
    S.E
    2 years and still going strong...
    london
    cheers guys- gonna try to do it the lazy way and if that fails i'll be prepared to do it the right way lol
    just wondering how come the springs jump as they are compressed and the gap between the top and bottom of the strut should never be longer than the spring.....and also as the whole strut and spring assembly turns as one.......
  1. its the top strut sleeve right???
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 20:25
  2. Spring Sleeve Mod
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2011, 22:56
vectra c spring sleeve
