Results 1 to 10 of 15
Thread: Info needed on turbochargers
    Regular Member LAZZEE RARSE's Avatar
    Jul 2010
    Sheffield
    Default Info needed on turbochargers
    basically i have a 1.8 petrol SRI vectra.
    and i am planning on using a second hand turbocharger from a scrapyard.
    but I wanted to know if im able to use a turbocharger from a diesel engine aswell, or am i only supposed to use a turbocharger from a petrol engine.
    I also wanted to know which manufacturer uses the best turbochargers for power gains.
    Regular Member Jezzy's Avatar
    S.E
    Have you done your homework on this? It's not as simple as bolting on a turbo - what will control the boost (not your ECU, as it's not programmed to do so). How will you lower the compression ratio?
    There was a kit available for the 1.8 to turbocharge it, but I'm sure it was the best part of 4 grand or so...
    S.E
    You'll need to make major modifications to be able to connect up the oil and water feed lines to the block or head, plus change the inlet manifold to give it an entry point for the charged air.
    Jul 2010
    Sheffield
    yeah i know where to get a turbo kit from but i may aswell sell my car and get an impreza sti instead of spending £4k+ alone on a turbocharger kit :/
    personally i did believe it was just a case of bolting on a turbocharger and intercooler.
    i have a couple of mates what have done the same with there cars, bought second have turbochargers and intercoolers, bolted them on and they got results,and none of them had any problems,
    except one guy which added just the turbocharger with no intercooler, practially destroyed the clutch. :/
    all there cars are older then mine and smaller engines, but i didnt think it would be any different if i did the same on my car
    but thanks for the advice jeezy
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You would need an oil feed, water feed, new manifold or addaptor to fit the turbo, new pipe work for the intake air, intercooler would be nice and the a waste gate should be fine for controlling boost as long as you are keeping it very low, sort of 5psi level. A diesel turbo would need a vacuum control and has no water cooling so would probably over heat in a petrol exhaust. The diesel turbos aren't designed to deal with high revs, so you would probably over speed the turbo in a petrol.
    S.E
    Quote Originally Posted by LAZZEE RARSE View Post
    ...all there cars are older then mine and smaller engines, but i didnt think it would be any different if i did the same on my car
    Lots of things that were once possible on older cars can't be done on newer ones, as the cars get more "intelligent" - On the Vecs you can't even switch the tail light bulbs for LEDS for example. Serious mods like turbos are getting harder and harder to do....
    West
    just trade the 1.8 for a car with a turbo
    S.E
    MG Metro Turbo, perhaps?
    West
  1. Info needed please
    By pipamish in forum Styling
    Last Post: 12th December 2011, 00:09
  2. bit of info needed plz
    By the fisherman in forum The 'Off Topic' room
    Last Post: 14th March 2011, 22:22
  3. EGR info needed
    By spm1966 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 20:40
  4. help \ info needed please
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 11:55
